d16y7 - will clutch and flywheel for a d15b2 engine work?
I have a 97 civic dx with a d16y7 motor stock and i need a clutch, I have a new clutch and flywheel for a d15b2 out of an 89 hatch. I noticed the only difference seems to be the 89 clutch disk is 200mm in diameter while my 97 is 210mm in diameter. Would downsizing have any effect? I have a flywheel with the new downsized clutch as well, would that fit in place of my old flywheel, i dont see any reason it wont seeing as splines and diameters are all the same. Let me know any opinions thanks.
i dont think u will have a problem just alil less surface area to grab at the clutch. should all fit u have to use the clutch that goes to the tranny ur using. i believe the splines are a different count.
matt's hatch
Jan 30, 2010 06:03 PM
