90 CRX - no dash, instrument, or tail lights
My son has a 90 crx hatchback. he called me tonight to tell me that although the car starts etc he has no dash lights instrument light or tail lights. he changed the fuse and NOTHING
if any one at all has any advice on how to proceed please let me know
check all the grounds first. check the ground wire that goes into the bezel also, had one car one time where that ground went bad had to run a new one back to the chassis got all the cluster lights back on.
I'll bet you ten bucks the dimmer switch wire on for your radio is grounding out on the chassis itself. Check that and make sure it's not grounding out, change the fuse and you should be good!!
i wish i could be so lucky. i have no instrument lights at all. 91 civic lx 4 door. red with blk wire is hot to the back of the cluster. radio light wire also hot but no lights. running lights all work but no gauge lights.
my93civiceg
Feb 8, 2009 11:04 PM
shaferz
Feb 29, 2004 07:19 PM
