N/A rebuild - what headgasket?
Old Jun 5, 2011 | 09:37 AM
Rasmusm's Avatar
Default N/A rebuild - what headgasket?
Hey
So my car recently blew a headgasket after just 3000km maximum.
We put in a new original Honda headgasket torqued it to spec. But never the less I believe we reused the headstuds.. Stupid yeh.. well
So Im gonna order a new headgasket, should I just get a new one from Honda? Or is there any other brand that I havnt heard of?
Its a h22a2 with 11.5:1 CR, skunk2 pro2 cams, eagle rods so on.
What do you think? Im defiantly gonna order the ARP headstuds though
Thanks all,
Best regards Rasmus
Denmark
Old Jun 5, 2011 | 11:42 AM
AznBlueBoy's Avatar
Default Re: N/A rebuild - what headgasket?
oem honda or cometic
Is your motor tuned or did you just rebuild the motor with all those things you listed and started driving?
Old Jun 5, 2011 | 11:57 AM
Rasmusm's Avatar
Ofcause not, its tuned with eCtune.. And thanks for your input think ima go with the honda gasket
Old Jun 5, 2011 | 12:27 PM
nus_dogg's Avatar
I heard Cometic leaks which is why I returned the one I bought from a local performance shop then bought an OEM one from Honda. I recommend you use copper spray on the gasket before you install it just to ensure that it doesn't seep or anything.
Old Jun 5, 2011 | 01:07 PM
AznBlueBoy's Avatar
I'v been using a cometic for 3-4 years now with no problems.
I would use an oem honda gasket but I have a 89mm bore and had to go with cometic.
Golden eagle is another option.
Old Jun 5, 2011 | 07:20 PM
nus_dogg's Avatar
Thats good to hear; tons of other threads I read are complaints from Cometic users which made me to believe that mine will leak as well, so I returned it and went with OEM.
Old Jun 6, 2011 | 03:16 AM
q16racer's Avatar
ive used cometic a few times as well with no problems.
Old Jun 6, 2011 | 05:57 AM
Rasmusm's Avatar
Thanks alot for your input.
Think im gonna stick with the oem honda. I believe that it was my headstuds that failed because of being reused :/ too bad, nothing to do about it..
Old Jun 6, 2011 | 07:13 AM
typemismatch's Avatar
Honda owns me
I just had GE build my block for turbo. They recommended the OEM headgasket or their gasket, which is the OEM Honda one that they machined to match to my block.
Old Jun 6, 2011 | 07:30 AM
Rasmusm's Avatar
Cool thanks !
Old Jun 6, 2011 | 09:29 AM
Rasmusm's Avatar
One question guys :-)
I talked with importreplacement parts.
They have this head gasket on their site:
http://catalog.importrp.com/item.wws...e&weight=1.340
Stone/Ishino was told its the original equipment manufacturer for Honda. What do you think? Safe to buy if its the same as honda's
jesse0880
Dec 3, 2009 07:29 AM
KansasKev
Apr 15, 2008 08:17 PM
Mr.Death
Jul 18, 2006 10:04 AM
blowbyu24
Oct 10, 2005 08:57 PM
Mike95lude
May 12, 2004 09:51 AM
