What am I doing wrong? (timeslip inside)
So I went to the track for the first time, and heres my slip
Reaction - 1.080
60 foot - 2.512
Mid mph - 650.74 (errr wtf)
660 - 0.001 (??)
MPH - 88.75
ET - 15.856
This is a 1998 civic coupe, b16 swap. I/H/E, type r cams, type r short shift, power steering delete, p28 ecu, chrome chip + tune, redline at 9,256 rpms
I feel my time should be faster.....? I launched at 6000rpms, spun all of first and most of 2nd gear
In the 8th mile I lost to a type r swapped ej6 by a fender at most, and was faster than a 93ish prelude h22 from 0-120+ (high 14 cars no?)
This is full interior + 17inch rims(arent that heavy) with no name tires
anyone know what i should be running
Reaction - 1.080
60 foot - 2.512
660 - 0.001 (??)
MPH - 88.75
ET - 15.856
i think your times are pretty good for a heavy car with just a stock b16 . I dont really think you can go much faster with what you have .
what would i need to do in order to make it a high 14?
i couldnt really tell you, only repeating what the previous owner told me. I bought the car like this about 3 weeks ago. car idles at 700ish(so i know the needle isnt off), rpm cluster ends at 8000 but the needle will keep going a long way's into the abyss
60 foot is terrible, 17s don't help at all, and I highly doubt you are making power to 9200rpms.
My friends stock 1998 Civic Ex Coupe with just an intake went 16.0, so the car should be able to do better than a 15.8 lol
You dont need slicks. You need to learn how to drive. "I launched at 6000rpms, spun all of first and most of 2nd gear" .... you just explained your problem. Spinning = going nowhere. Walk it out in 1st gear like your leaving aggressively from a stop light with no wheel spin but not bogging, pre-load with ebrake at the launch. 4500-4800 for launch rpm, tires at 30psi....I laugh my *** off when i see these idiots spinning like crazy off the line. 2.0-2.1 60's are no problem on a street tire.
Go from 17's to a 15" wheel/tire combo and i bet youll see at least a 2-3mph increase in trap..
I know when i went from a 195/55/15 to a 205/45/16 and lost 1.5mph.. that was on a car that was dead consistent... changed to a 205/50/15 and it went back to what it was before... and nothing else changed
cut a .035 lite
60 ft. 2.0 or 2.1
14.68 et.
2 step for 5500 and one for 5000
Ahhh yea going vtec b16 head soon .
i really cant complain .
good luck
You're reving too high, which puts you past your shift point. ITR cams dont make much past 8300rpms.
Learn to launch, you'll need better tires/rims as everyone else has said.. i'd try to learn how to preload and feather first. Seems you're just dumbing the clutch and thats why your spinning.
yes i will admit i am new to launching. i just rev to 6000 and dump the clutch
today on a long empty street near my house i tried dumping the clutch at around 4500, and while it felt like it hooked very well, it was a good 1.5 secs until i got into vtec (it kicks it at about 5800 rpm).
is it a big deal if im not in vtec from the launch? or must i always stay in it
Once you switch to a light set of 15" wheels and a decent set of tires you will realize how foolish 17" rims are on a B16 powered honda. It will be a night and day difference on the street and the track.
My unstripped EG STD B16a2 S4C gearbox with a ported P30 manifold 68mm TB DTR headers went 14.8@94mph the other night with a 2.1 60' time we are using 15" no name tires,we shift at 8200rpm and launch at 3000rpm and still get bad wheel spin in 1st and 2nd gear.
ok i am going back to the track tonight hopefully. can't do anything right now about the rims//tires but i will launch a lot lower and post up results!
btw a bit random but does concrete change anything??
where i went originally is an old airport turned into a drag//circuit//drift trac, with the runway being the 1/4 mile
tonight i am going to a proper//normal track. maybe less slippage?
