Well this was a bad weekend
So I went to the casino and went i was pulling into the parking lot this happened.
My ball joint snapped.
Scary feeling.
Should I get new ball joints or go to odessey spindles and new ball joints?
I'm probably going to look at the other side as well.
Scary feeling. Should I get new ball joints or go to odessey spindles and new ball joints?
What are the future plans for the car? If you are just staying stock, wouldn't bother with the Odyssey spindles.
Inspect everything on that side and the other, replace everything that is needed....not good to have chassis parts fail while driving.
Mine snapped while trying to get on the freeway. The weight shifted to the driver side and snapped. I was very surprised that the spindle broke clean thru. No warning whatsoever.
Yeah i'm glad it was a parking lot not the highway. Future plans lower it with f&f, new bushings, maybe new swaybars, build the f22 with a h22 transmission, new tires and rims( still deciding), apexi muffler with 2.25 exhaust.
Definitely a new ball joint and axle. My '95 Prizm LSi did the same and the axle came out too. Good thing it's cheap; 30.00 or so for a new axle with core. Lol.
Is this car new to you OP? When you got your car inspected didn't the shop inform you of ball joint looseness.
Years ago when I had bought an a accord new to me I was warned by the mechanic checking the suspension that I had a bad ball joint
I don't mean to jack this thread.. But my GF was readin over my shoulder while I was readin this thread n she got scared... Cuz when I go over bumpers with my 96 accord. Theres clunkin noise in the front end somewhere. So she was like OMG I hope that doesn't happen to us with the kids in the car!!!
Anyways, how would I go about checkin to see if my ball joints r good or not?
Thanx
Thanx
To my knowledge, get the car in the air and rock the tire back and forth. If you see play, it may be bad. This is what my mechanic used to inspect mine. My ball joint gave out without warning. If possible, try to replace both at the same time.
Under the jack point? OR Under the control arm?
Pancho2193
Mar 11, 2011 05:10 PM
PandaBear
Suspension & Brakes
Jul 22, 2006 08:26 AM
Propulsion
Aug 3, 2002 08:52 AM
GruvyTune
Jul 22, 2002 10:01 AM
