smog fail please help
Old Jun 4, 2011 | 01:45 PM
miggy23's Avatar
Default smog fail please help
I took my car to get smogged and I failed because my ingition timing is off it says my rpms are to high it should be 700 and im at like 1180 does anyone know what could be causing this and how I can fix it and it also says I failed the NO (PPM) at 15 mph im at 923 and max is 825 any help would be appreciated I need to fix this ASAP please help HT heads I know someone on here has had this issue.
engine:
D15b2 stock intake and stock header the only mod is a full catback Apexi exhaust
Old Jun 4, 2011 | 01:47 PM
BiG ChOr!Zo's Avatar
Default Re: smog fail please help
pass it the carnalismo way...!!!
Old Jun 4, 2011 | 01:53 PM
miggy23's Avatar
dont have the funds bro to pay 150 to 200 being on unemployment sucks
Old Jun 4, 2011 | 03:57 PM
miggy23's Avatar
come on guys can anyone help me out here
Old Jun 4, 2011 | 09:42 PM
Alphacrewrocker's Avatar
set your timing at 16 btc thats the manufacture spec that should help to lower the rpm being so high
Old Jun 6, 2011 | 02:00 PM
miggy23's Avatar
Okay so I messed around with the timing and this is the outcome
and I also found this hose and it had a screw in closing it off took it out and thcar ran better does anyone know what it should be connected to
it looks like it comes from the back of the throttle or intake
Old Jun 6, 2011 | 02:06 PM
it connects into the charcoal canister...!!!
Old Jun 6, 2011 | 02:39 PM
4drEF's Avatar
Keyboard Humorist
A thief stole your charcoal canister and screwed your car!
You'll need that canister in place to help sort out your idle issue.
If the idle doesn't come down, then you will have to adjust the idle screw on the TB.
Hey - I'm looking at your pic that shows the distributor and that thing is turned really far. Is that before you did the timing?
When you did the timing, did you disable the electronic advance by putting a jumper in the service connector?
As far as your NO - how is your air filter?
What octane fuel did you have in when testing?
Have you ever ran injector cleaner or anything?
Did you have any 'additives' in the fuel when you tested?
When you went to the test, how long did you drive right before the test? did you have to wait long? did you leave the car idling while you waited?
Old Jun 6, 2011 | 03:36 PM
miggy23's Avatar
the charcoal canister is there but there is no where to connect that hose and the dizzy is turned that far to keep the rpms down before I started messing with the dizzy when I took the screw that was in that hose out it did lower the rpms and level it off a little then when I moved the dizzy it dropped perfectly at 900 rpm
Old Jun 6, 2011 | 03:47 PM
4drEF's Avatar
Keyboard Humorist
Here's a thread that shows how to remove it "properly", but also has decent pics for where the hoses route.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/charcoal-canister-answers-yes-i-searched-2010896/
Old Jun 6, 2011 | 03:54 PM
miggy23's Avatar
here are some pics of the canister
Old Jun 6, 2011 | 04:55 PM
miggy23's Avatar
Is this the right canister for my ride it only has hook up for two hoses not 3 the car had been running for a good time I had just gotten back from Victor Ville and I shut the car off before testing has a recent tune up oil change brand new dizzy and wires the filter is clean on the intake no additives in the engine at all and I was running regular unleaded gas the 89 one
Old Jun 6, 2011 | 05:32 PM
it connects to the nipple just under the black hose on top of the charcoal canister...the other part of it connects into a nipple on the throttle body...if the canister was swapped then just pick up a used one from a 88-91 chassis because it should have 3 connections...!!!
Old Jun 6, 2011 | 06:35 PM
miggy23's Avatar
Alright thanks I set the timing back to where I had it and now it seats right at 1000 rpm at idle also adjusted the throttle a little and it keeps it at 1000 is that cool to pass smog my car does have 250k miles
Old Jun 6, 2011 | 08:29 PM
fix the charcoal canister problem first then retest...!!!
Old Jun 7, 2011 | 05:55 AM
miggy23's Avatar
Will do thanks for the help guys
Old Jun 7, 2011 | 07:55 AM
4drEF's Avatar
Keyboard Humorist
Don't turn the car off before the test. You want the cat to be as hot as possible.
Ideally you want to have the car tested right when you pull up. Idling for a long time will have adverse effects as well. So... I think it would be fair to idle for no more than 5 min.
I zoomed in the best I could on your pic and it looks like you do have the 3rd port and it connects just like Big Chorizo pointed out.
Not sure how you are setting your timing? Do you have a timing light?
Do you understand the service connector to defeat ignition advance?
dc4teggiehatch
May 4, 2008 08:17 AM
Jonknee
23
Feb 27, 2008 04:10 PM
doubleoazn03
Sep 22, 2007 01:56 PM
VtecGsr95
Sep 20, 2005 04:42 PM
DC4_MADMAN
May 31, 2005 11:12 PM
