Courtesy Light
My passenger side door courtisy light hasn't worked since I got the car.
Car:
1991 Honda Accord LX 2 Door Coupe
Here's what it does:
Already Checked
Question:
Any advice would be appreciated thanks!
Car:
Already Checked
- Fuse is good since driver side works.
- There is no power to the light socket or wire at all.
- The light is good becuase I swapped it with the other light.
Question:
- Is there a switch for the light or does it run off of the door switch that turns on the light inside the car?
- Where do the wires from the light go? Do they go under the hood or do the travel under the dash board.
The switch is in the b pillar. The wire runs down the b pillar and you need to pull the sill cover(plastic cover in the door opening) and the b pillar cover to find the connector. I'm not sure how long the wire is.
http://www.hondacarforum.com/honda-3...accord-ex.html
If you find the switch, try pressing it a listen for a click. It should pop out when the door opens.
EFSiR
Jun 1, 2003 03:12 PM
