Dad BLAM CEL!
Old Jun 3, 2011 | 03:53 PM
StreetLimitz89's Avatar
Default Dad BLAM CEL!
okay, i have a 98 acura cl F23A1 engine, with over 250k
i had the valves adjusted by a honda tech at the Stealer and since then i have noticed at LOW rpms 1200-2300 it sputters HORRIBLY.
today going out, it started doing it REAL bad and it threw 2 codes at me
p0301 CYL1 MisFire
p1399 mfg control ignition system OR misfire.
the EGR valve was completely stopped up, so i removed it cleaned the EGR runners and the EGR valve itself, Seemed to clear it up a tad bit but its Still sputtering like a ****.
Any Ideas?
Old Jun 4, 2011 | 04:56 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Dad BLAM CEL!
Check the spark plug wires and spark plugs. Also check for any missing or loose grounds that may have been attached to the cam/valve cover. The tech may have missed them or not installed them properly.
Lowassteg
Dec 23, 2015 07:15 AM
sheist42
Jan 16, 2014 08:31 PM
adamrich33
Sep 17, 2013 09:13 AM
dakotajfish
Feb 22, 2013 10:01 PM
dynamitezz
Oct 28, 2006 08:07 PM
