which cam for max power and best idle (H22A)??
Old Jun 3, 2011 | 01:08 PM
hingi's Avatar
Default which cam for max power and best idle (H22A)??
i need a cam, that have lowset possible idle and max power for the H22A engine.
at the moment i have the Pro2 installed, but the idle need about 1100rpm and i need 800-900rpm max
it is a daily drive car with some circuit races ~285PS (240whp+)
which cam can perform that?
JUN stage 2R
Crower 2
Crower 2 3/4 Race
Crower 3
Crower 3 full race
or some other cam?
engine facts:
ENDYN head (welded)
ENDYN block 2286ccm
12,0: compr.
76mm exhaust
thanks a lot for helping
Old Jun 4, 2011 | 12:18 AM
HdeucedeuceA's Avatar
Default Re: which cam for max power and best idle (H22A)??
From what I hear, your tuner should be able to make it idle lower/smoother with these cams.
Old Jun 5, 2011 | 11:24 AM
tagperformance's Avatar
sk2 stg3's
Old Jun 5, 2011 | 11:47 AM
JDM JEFFREY's Avatar
Pro 1's
Old Jun 5, 2011 | 02:58 PM
TheShodan's Avatar
Moderator
He needs to ensure that they were properly degreed to get the better idle, then tune it to suit.. Changing cams would be a waste of time, money and effort.
Old Jun 5, 2011 | 03:00 PM
DDTECH's Avatar
Pro2s
Old Jun 5, 2011 | 04:17 PM
crazes's Avatar
Moderator
pro 2's have it and i idle at 1200rpm smooth
Old Jun 19, 2011 | 08:25 AM
hingi's Avatar
thanks for all the infos!!!
i think the Crower 2(63422A-2) is the only cam which can make a nearly stock idle ??
but i think they will make much less power as my Pro2
2nd base change:
the Pro2 are very loud (valvetrain) when the engine run idle
the car is for street/daily drive and sometimes circuit races
Old Jun 19, 2011 | 08:54 AM
koczeka's Avatar
s2s3 or customs
Old Jun 19, 2011 | 02:46 PM
nus_dogg's Avatar
2nd base change:
I have the pro2 in my H22A right now, and I agree, the valvetrains are loud at idle with valve lash in spec from Skunk2 but that doesn't bother. I like the power it made.
Old Jun 23, 2011 | 11:38 AM
hingi's Avatar
what did you think about this cams?
http://www.crower.com/products/camsh...-per-pair.html
i think they are yery good for me??
or BC 2 (BC0032)
http://www.briancrower.com/makes/honda/h22h22a.shtml
thanks!!
Old Jun 23, 2011 | 10:30 PM
I'd personally only run the Skunk2 Pro series on the H.
haulinhonda
Mar 11, 2013 02:11 AM
GSR_96814
Sep 19, 2006 01:44 PM
dohcMONSTER
Feb 3, 2004 05:04 PM
94civicx
Jan 1, 2002 09:26 AM
Silude93
Oct 3, 2001 07:09 PM
