02 civic with bad times
I have a 02 civic 4 door auto that will not go over 2000 rpm and will not go faster then 20mph. It has a check engine light but for some reason it cant be read out. I have tried over 5 different scanners but they all say error.
If you swap ECU's, make sure you get the key, too. If the key and ECU don't match, you'll need a dealership to reflash the ECU so that the immobilizer doesn't prevent the car from running.
You can troubleshoot the circuits at the ECU, but if you haven't done it before, I don't recommend diving into it.
