whats the right way to bleed clutch
Old Jun 2, 2011 | 12:08 PM
niceprelude's Avatar
Default whats the right way to bleed clutch
i have changed the master and slave cylinder for 92 civic ,but the clutch come up slowly and weak.How i bleed it is,press clutch 10 times and hold it down,than release the bleeder bolt,than close it.I repeat it several times.is that the correct way
Old Jun 2, 2011 | 12:26 PM
slammed4dreg's Avatar
Default Re: whats the right way to bleed clutch
u might have a leak. did u bleed it with the cap off or on?? also when bleeding do u have a vacuum hose submerged in a can of brake fluid??
Old Jun 2, 2011 | 12:52 PM
i try both cap on and off,but i never use a hose with brake fluid
Old Jun 2, 2011 | 12:55 PM
sextav6's Avatar
taking a hose from the bleeder screw and submerging the end in a little bit of brake fluid will show you whether you still have air in the lines i.e bubbles will come out of the hose with the old fluid. make sure you check the level in the reservoir every couple times
Old Jun 2, 2011 | 01:03 PM
plus it guarantee's no air goes into the lines.
Old Jun 2, 2011 | 01:17 PM
that_boy_sammy's Avatar
Make sure brake fluid is full, pump clutch 5-10 times, hold it down, loosen the nipple then tighten. Repeat that 5-10 times. Submerging makes things precise but you don't really have to do it and it shouldn't effect your clutch as much as you are saying.
Old Jun 2, 2011 | 01:55 PM
Former User's Avatar
The $4 One-Man Brake Bleeder tool works well for me.
Old Jun 2, 2011 | 02:50 PM
RON J IS THE MAN!! ALWAYS BUSTS OUT WITH ALL THE DIAGRAMS
ccoake1
Honda Civic (2006 - 2015)
Jan 14, 2017 09:19 AM
gulfview
Jun 16, 2007 09:44 AM
BB1_VTEC
Jul 12, 2006 09:41 AM
Luchini
Oct 16, 2005 06:06 PM
Shotman
Jan 12, 2005 05:48 PM
