Front Lower Arm Bolts
Old Jun 2, 2011 | 08:40 AM
Atomic1's Avatar
Default Front Lower Arm Bolts
How often do front lower arm bolts sieze? Am replacing my axles and am wondering how likely I'll run into a siezed bolt weekend killing fiasco. Seems like the rear LCA's are more prone to seizing, but am wondering about the fronts. 2000 civic
Old Jun 2, 2011 | 10:22 AM
kyden's Avatar
Default Re: Front Lower Arm Bolts
your lower shock fork bolt should come out fine (its a nut and bolt). you might have issues with the upper fork bolt though, since the body is threaded. it should be fine if you use air to get it off. if you try it with a ratchet it might break. mine have come out no problem, but others haven't been so lucky.
JDMjackyboy
Jun 5, 2011 08:15 PM
thundernoodle
Jul 10, 2010 03:54 PM
maynards_ek
Dec 1, 2007 01:35 PM
92vx6
Jun 20, 2004 07:55 AM
Ragezero76
18
Sep 22, 2002 04:23 AM
