60trim turbo
Old Jun 2, 2011 | 08:28 AM
spoolinvtec54's Avatar
Default 60trim turbo
So I found a turbo for my b16 I was wondering what will the turbo max out hp it's t3/t4 Garrett 60ar compressor and 63ar on the hot side.
Old Jun 2, 2011 | 09:28 AM
TheShodan's Avatar
Moderator
Default Re: 60trim turbo
430whp is as far as it goes. maximum efficiency boost is about 21-22psi of boost pressure. As a matter of general principle, never drive a turbo at its maximum levels on a regular basis
Old Jun 2, 2011 | 11:09 AM
Could I change the turbine wheel out so I can make more hp out of it.
Old Jun 2, 2011 | 12:00 PM
TheShodan's Avatar
Moderator
You could, but then you would lose all of the characteristics of any response to it. it could give you about 50hp, but that's about it. By the time you install another exhaust wheel, and rebalance it to the compressor wheel, that money could be put to a more powerful unit
Old Jun 2, 2011 | 04:50 PM
Ok thanks I'll just look for something different
Old Jun 2, 2011 | 04:56 PM
TheShodan's Avatar
Moderator
We all may be able to help, if you tell us your setup, goals, engine, fuel, etc..
Old Jun 3, 2011 | 02:39 AM
Stock b16 block with build head with skunk2 tuner 1 cams I just want close to 350hp. But some time next year but in my ls/vtec 2.0 I just want like 450hp for right now. But how can u tell from a t3t4 to a t3t4e.
Old Jun 3, 2011 | 05:18 AM
TheShodan's Avatar
Moderator
The T3 and T4 describe simply the housing and wheel families. There are over 20 - 30 different wheel combinations that can fit within that family. People know based upon the wheels themselves and the amount of pressurized airflow they produce. In your case, the T3/T04E 60 "trim" (based upon a standard 2.559" wheel diameter turbine package) uses about 50-52lbs/min. while other GT3540E or Precision SC61 can be in the same housings and produce about 61lbs/min, and still be in the same housings.
So do you want 350 right now or 450whp right now?. Your statement is ambiguous. IF the goal is using pump gas 93 octane, they require 2 different turbochargers to do it.
Old Jun 3, 2011 | 08:08 AM
Right now 350
Old Jun 3, 2011 | 04:18 PM
TheShodan's Avatar
Moderator
Originally Posted by spoolinvtec54
Right now 350
Then keep what you have, and can get 420whp maxed out on race fuel (or 110 octane equivalent) with what you have now.
When you want 450whp on pump gas, time to upgrade.
Old Jun 5, 2011 | 09:36 AM
How can u tell if my turbo is t3t4e Or a t3t4b
Old Jun 5, 2011 | 10:18 AM
racebum's Avatar
simple way is to measure the inside diameter of the outlet. a B case is 45mm and an E case is 50mm
Old Jun 5, 2011 | 10:28 AM
TheShodan's Avatar
Moderator
Only pics that I have here to help in case you can't measure properly.
T04E cover is the far left. The middle and right are T04E covers.
Old Jun 5, 2011 | 11:07 AM
Ya I can measure. Just got a micrometer.
Old Jun 5, 2011 | 01:14 PM
So I measured the compressor housing inlet I got 62mm.
Old Jun 5, 2011 | 01:17 PM
racebum's Avatar
i thought you were trying to figure out if it was a b or e? measure the id of the OUTLET
Old Jun 5, 2011 | 04:10 PM
My bad your talking about where the down pipe hooks up
Old Jun 5, 2011 | 04:45 PM
racebum's Avatar
compressor cover has zero to do with the exhaust side. the cold side has an intake your air filter bolts on and an outlet your boost tube would bolt on to. the inside diameter of that outlet is either 45mm if it's a B cover or 50mm if it's an E cover
Old Jun 5, 2011 | 05:33 PM
It's 45mm thanks for the help.
Old Jun 5, 2011 | 06:34 PM
racebum's Avatar
sounds like a potential vtrim. from what i've gathered they will make 350-380whp before you run into surge issues. since it's using the .63ar it's not a bad turbo, especially since you already have it
Old Jun 5, 2011 | 07:23 PM
TheShodan's Avatar
Moderator
D'OOHH. Don't confuse the boy more than he is.. he's just now getting the number "thing" straight. Now he's going to ask what That means
Old Jun 5, 2011 | 07:29 PM
racebum's Avatar
LOL
Old Jun 6, 2011 | 08:03 AM
Just trying to learn that's all.
Old Jun 6, 2011 | 08:45 AM
TheShodan's Avatar
Moderator
No one's faulting you for that.. (This is good). But you need to learn things one step at a time with this nomenclature before you get introduced into too much. I find that when people learn enough just to be dangerous, they tend to make bad choices just on that little information.
komat
Aug 9, 2007 02:07 PM
Frozen E
Apr 13, 2006 02:50 PM
UNforgivABLE
Oct 1, 2005 09:51 PM
mrbsponge
Sep 29, 2004 06:11 PM
