92 no spark and no fuel pump
Old Jun 2, 2011 | 07:53 AM
transman46582's Avatar
Icon6 92 no spark and no fuel pump
Here is how it started. My son broke the key off and then took the harness off the back of the cylinder and used a screw driver. that worked for a while and the harness fell apart. So I got a wire diagram and tried to use togo switches this worked to turn the engine over still no start. Got a different key cylinder with harness and still no spark or pump. Did resolder main relay and still nothing. HELP..............
Old Jun 2, 2011 | 08:42 AM
phootbag's Avatar
Default Re: 92 no spark and no fuel pump
By chance check the ignition fuse under the hood?
Old Jun 2, 2011 | 09:09 AM
I have checked that and just about everything under the sun, is it possible that i could of fried something when i hooked up the toggle switches, or even the main be bad even though i soldered it?
Old Jun 2, 2011 | 09:10 AM
the ignition fuse is the 50 amper?
EJ1 Ekenziro
Jan 1, 2019 02:27 PM
eesupra420
24
Aug 5, 2011 07:10 PM
b16hatch620
Sep 19, 2010 06:42 PM
frost_0ne
Sep 13, 2005 01:02 PM
MikeNice
Jun 28, 2005 05:32 PM
