K20A2 Fuel Rail Question
A few of you have seen my other posts and questions and some have been very helpful as I perform a K20 swap in a Fiat X1/9. Thank you for the continued help.
I am about to start plumbing the fuel system and have been noodling for a while the fact that the fuel rail has ONE fitting for a fuel hose. Regardless of what I am working on, I am used to any common rail system having TWO hose fittings--supply and return/flange for FPR. What is going on here? Did Honda have some system in which a regulator worked to bleed excess pressure BEFORE the fuel reaches the rail? Did the ECU cycle the fuel pump according to pressure need? I am guessing the former, but the latter is possible.
Thanks ever so,
Jonathan
Thanks ever so,
Jonathan
It's common for people with higher horsepower setups to make a return line from the fuel rail.
Also, I hope you post your build project here:
http://www.k20a.org/forum/forumdisplay.php?f=122
They would love to see it. As would I.
Bantam
Mar 7, 2003 08:58 AM
