Suspension & Brakes Theory, alignment, spring rates....
SWAY BAR? EK hatchback front
Old Jun 2, 2011 | 02:33 AM
kungphu's Avatar
Default SWAY BAR? EK hatchback front
hi i bought a 99 civic ex front sway bar and the ctr front LCA do i need anything else to install the front sway bar? i have end links and d bracket and bushings also. Do i need the ctr/si forks? or i can use my stock forks?
also im using a ex front sway bar which i think is 22mm and i have a blue jdm sway bar that came off the CTR not sure how big it is.. will i have any problem with oversteer? or understeer? i dont wanna crash my car on a on ramp.. sorry if i sound stupid i dont know a lot about this stuff
Old Jun 2, 2011 | 03:56 AM
BlueIntegraBoy's Avatar
Default Re: SWAY BAR? EK hatchback front
You need the front forks as well.
Old Jun 2, 2011 | 04:49 AM
kyden's Avatar
are you using the ex or ctr bar? si/ctr style endlinks won't work on an ex bar.
Old Jun 2, 2011 | 05:25 AM
kungphu's Avatar
im using ex bar with ex endlinks
Old Jun 2, 2011 | 05:29 AM
kyden's Avatar
those won't work. si/ctr arms have a ball joint style endlink.
Old Jun 2, 2011 | 08:26 AM
kungphu's Avatar
[QUOTE=kyden;45385844]are you using the ex or ctr bar? si/ctr style endlinks won't work on an ex
so si/ctr endlinks wont work and ex end links wont work either?
which endlinks will work?
Old Jun 2, 2011 | 10:38 AM
kungphu's Avatar
anybody know if thats a good set up? ex front sway and cusco 24mm rear sway...? will i get oversteer or understeer?
Old Jun 2, 2011 | 10:39 AM
kungphu's Avatar
i think the front ex bar is 22mm
Old Jun 2, 2011 | 12:16 PM
You can only use the 26mm SI/CTR front sway with the SI/CTR front LCA. I must have missed that detail above. But you need Si/CTR front forks with Si/CTR front LCAs.
Old Jun 2, 2011 | 12:53 PM
wannaBjdmca6's Avatar
why'd u get ctr lca?
just go to a junkyard and get the back piece of the ex lca and endlinks and use ur ex bar
whatever lca you use, use its corresponding end-link, fork. SWAY BAR
using CTR lca, ctr forks, si end-links and ex sway bar WONT work cos end-links wont fit on the ex bar.
Old Jun 2, 2011 | 01:08 PM
phunhaus's Avatar
It's a FWD car, you will always have understeer.
Old Jun 2, 2011 | 05:36 PM
kungphu's Avatar
so what kinda end links i need to install the front sway bar to the ctr LCA's
Old Jun 2, 2011 | 06:07 PM
kungphu's Avatar
i have to buy these end links? http://compare.ebay.com/like/3504584...=sbar&_lwgsi=y
Old Jun 2, 2011 | 06:33 PM
You can ONLY use the Si/CTR 26mm front sway bar using the Si/CTR front LCAs. In order to use the EX sway bar you NEED EX or LX front LCAs.
Old Jun 2, 2011 | 06:46 PM
kungphu's Avatar
damn!!! so i need ctr or si swaybar w/endlinks.. **** my life why do i have this damn ex swaybar.. so i can't just switch out the endlinks and use the ex bar?
Old Jun 2, 2011 | 06:54 PM
For the nth time, you can't...
Si
EX
Can you see the difference?
Old Jun 2, 2011 | 06:57 PM
kungphu's Avatar
can i use itr front sway and endlinks?
Old Jun 2, 2011 | 06:58 PM
kungphu's Avatar
yeah the sway bars are different.. damn.. dunno why they seller threw in the sway bar for free when i can't even use it... i thought i was getting a deal too lol
Old Jun 2, 2011 | 07:00 PM
kungphu's Avatar
or gsr front sway?
ZombiePharoh
Suspension & Brakes
Feb 23, 2014 08:36 PM
Ephekt
Suspension & Brakes
13
May 6, 2013 12:40 AM
Cboi
Mar 5, 2007 06:01 PM
elitesi8
27
Oct 25, 2006 01:56 AM
saveacivic
Suspension & Brakes
Apr 15, 2006 12:31 AM
