ls vtec back to ls timing belt.
Old Sep 30, 2002 | 06:36 PM
ILOVEGIRLS's Avatar
Default ls vtec back to ls timing belt.
what timing belt do i use when i need to go back to and ls head? its a b18b block with a gsr head, with a vtec oil pump and water pump. thanks. i dont wanna mess up and make the timing belt slip.
Old Sep 30, 2002 | 07:43 PM
dohcsideSi's Avatar
Default Re: ls vtec back to ls timing belt. (ILOVEGIRLS)
you are going back to a ls?? just use a ls timming belt. the oil pump gear and water pump gear are the same
Old Sep 30, 2002 | 07:48 PM
ILOVEGIRLS's Avatar
Default Re: ls vtec back to ls timing belt. (dohcsideSi)
are u positive about he oil pump and water pump gears being the same?
Old Sep 30, 2002 | 07:56 PM
sgT's Avatar
sgT
Using non vtec water pump, use non vtec timing belt
using vtec pump, use vtec belt(b18c)
everything is same but water pumps
Old Sep 30, 2002 | 09:34 PM
salbaje's Avatar
Default Re: ls vtec back to ls timing belt. (sgT)
i second this
Old Sep 30, 2002 | 11:07 PM
ILOVEGIRLS's Avatar
is ther a definate way i can tell if the water pump i got is relly a vtec one? thanks.
Battle Cat
Apr 30, 2005 10:21 AM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
lsvtechatch04
May 8, 2004 03:20 AM
madhatter07
Jul 7, 2003 08:42 PM
275Performance
Jan 4, 2003 04:45 PM
