Calling all dj.'s tops for sale!
Old Jun 1, 2011 | 06:48 PM
dj_seloe's Avatar
Default Calling all dj.'s tops for sale!
Just added Vinyl & iBook G4
Ok the time has come!!!
If you don't know well dj.ing and music is my first passion then comes cars and motorcycles...
Im selling my tops because I don't have the time or want anymore and would be best if someone could put it to use this is what i got for sale...
2 Technics SL-1200M3D with Shure M44-7 needles
Technics introduces the SL-1200M3D Direct Drive turntable. The M3D uses the same inner workings as the MK2, but it's been further re-engineered for smoother, nonstop performance. Because, as anyone who's ever thrilled to club music can tell you, the beat must go on.
Technics Slip Pad and No-hinge Dust Cover The custom Technics slip pad is included with the SL-1200M3D. This mat protects your records from the metal plate on which they spin.
Additionally, the Technics SL-1200M3D is equipped with a convenient no-hinge dust cover. Professional DJs will appreciate this feature, as it lets you perform free-style at a gig, and then quickly and easily cover up the equipment to protect it when you return to your home or the studio.
Recessed Power Control This turntable comes with a specially designed recessed power control, so it can't be activated accidentally. This feature makes it certain that once you start the music, it will never be unwittingly stopped!
Direct Drive The SL-1200M3D is equipped with Technics original integral rotor-platter DD (Direct-Drive) motor and unwavering quartz DD accuracy. The precision molded aluminum diecast cabinet and heavy rubber base material help absorb unwanted vibrations, while the turntable includes a head shell stand on the cabinet.
The SL-1200M3D also has a total quartz locked continuous pitch adjustment up to +/- 8%, and comes equipped with a convenient pitch reset button.
Technics original integral rotor-platter DD (Direct-Drive) motor Unwavering quartz DD accuracy: wow & flutter 0.01% WRMS, rumble -78dB (DIN B) Very high torque for quick start-ups Total quartz locked continuous pitch adjustment up to +-8%. Equipped with reset buttonHead shell stand on the cabinet Disc slip mat equipped Precision molded aluminum diecast cabinet and heavy rubber base material helps absorb unwanted vibrations Highly sensitive low-mass tonearm with gimbal suspension Helicoid tonearm height adjustment Pop-up stylus illumination
Shure 44M-7 Needles
Model M44-7 SPECIFICATIONS
Skip Resistance: ultra high
Output: ultra high
Record Wear: ultra low
Sound Emphasis: big bass
Tone Arm Mount: Standard 1/2 inch
Cartridge Type: Moving Magnet Output Voltage:
Typical at 1 kHz
9.5 mV RMS at 5 cm/sec peak velocity
Recommended Load: 47 kilohms in parallel with 450pf Tracking Force:
Effective at stylus tip
Range: 1.5 to 3 grams Stylus Cantilever:
Shure Type S
Heat-treated aluminum alloy / tubular
1.6 mil wall thickness / 34.5 mil diameter Diamond Stylus Tip
Polished natural gemstone: Spherical
Radius: 0.7 mil
Frequency Response: Essentially flat from 20 to 20,000 Hz
Stereo Channel Balance: Within 2 dB
Channel Separation: Typical at 1 kHz: 20 dB
Weight: 6.7 grams
Height: 15.9 mm Accessories Included:
Attached flip-down Stylus Guard
Headshell Screwdriver (Phillips)
Extra Set of 4 Headshell Wires (4-99)
Stylus Cleaning Brush
Headshell Weight (3 grams)
User Guide
Mounting hardware
Stylus guard
Numark EM-460 mixer with Korg Kaoss pad
KAOSS PAD:
Sixty"effetcs programs"
Sampler(5 sec. at 48 KHz)
MIDI compatibility
Real-time effects processing
X-Y pad
Seperate parameter controls
Hold switch to lock settings
100% digital processing on all inputs
KAOSS technology under license from KORG
MIXER:
7 line, 3 phono, 2 mic inputs
Front panel Nuetrik mic input with bass-treble-talkover
Master includes balanced outputs, 3 band EQ and pan control
Completely assignable and replaceable ALPS crossfader
Fader start
2 zone outputs
Split/bend headphone cueing
Bas, middle, treble, EQ with kill on every channel
Numark CDN-88
FEATURES
• Dual rack mountable CD player
• Real time scratching
• Built in Beatkeeper™ with auto-mixing and synchronization
• Interactive DSP effects, reverse
• ±6, 12, 25 and 100% pitch control
• ±100% KEY LOCK with key control
• 2 complete seamless loops with 3 hot stutter starts
• Track sequence programming
• Digital output, CDR compatible
• Fader start and relay
• 48 seconds of buffer memory for Anti-Shock™
• All-rubber buttons
DECIDED TO ADD MORE TO THE PACKAGE!!!!
YOUR GAIN MY LOSS!
DEAL OF THE CENTURY
VINYL!
Adding all my vinyl about ten crates mostly hip hop some old classic rock some spanish stuff and my pride and joy deep house that you can't find anymore, and it's making a come back! this is a un written rule for dj's to get rid of the vinyl but ive decided to let someone enjoy it...
iBook G4 13'
This iBook G4 comes with serato program "serato box not included'
Also comes with Audcity program to turn all your vinyl into MP3's
and other goodies like photoshop.......
all you need is to hook up a AMP and speakers and your ready to go...
everything is in good condition everything works 100%
$1500 trying to sell as package
Old Jun 1, 2011 | 06:52 PM
alex22's Avatar
Default Re: Calling all dj.'s tops for sale!
price?
Old Jun 1, 2011 | 07:30 PM
dj_seloe's Avatar
Originally Posted by alex22
price?
$1500
Old Jun 1, 2011 | 08:27 PM
ek97sedan's Avatar
bump for a fellow DJ!
Old Jun 1, 2011 | 09:22 PM
dj_seloe's Avatar
thanks for the bump! fellow DJ....
Old Jun 1, 2011 | 10:54 PM
chubbsFTW's Avatar
bump
Old Jun 2, 2011 | 07:33 AM
dj_seloe's Avatar
ups
Old Jun 12, 2011 | 05:12 PM
dj_seloe's Avatar
up
Old Aug 8, 2011 | 06:02 PM
dj_seloe's Avatar
Added vinyl and iBook G4 to the package!
Old Aug 8, 2011 | 07:26 PM
My Db2 AinT JDM's Avatar
bump for i have the same mixer..it was the **** when it came out........i think it cost me like 5 bills back in 2002
Old Aug 9, 2011 | 02:35 PM
dj_seloe's Avatar
still minty fresh....
Old Aug 9, 2011 | 02:42 PM
reznunt's Avatar
Old Aug 9, 2011 | 04:15 PM
dj_seloe's Avatar
Originally Posted by reznunt
thanks for the bump....
Old Aug 9, 2011 | 07:53 PM
thatDAkid's Avatar
How much for just the mixer?
Old Aug 10, 2011 | 07:01 AM
dj_seloe's Avatar
trying not to part out....
Old Aug 10, 2011 | 07:10 AM
R.I.P 2000 Si's Avatar
WOW this is a good deal...
Old Aug 10, 2011 | 09:30 AM
deviusdragger's Avatar
From: im nothing from no where im no one at all, ca
Bump for looking
Old Aug 10, 2011 | 07:45 PM
dj_seloe's Avatar
yes it iscome up for any dj......
Old Aug 11, 2011 | 01:07 PM
dj_seloe's Avatar
up
Old Aug 14, 2011 | 06:32 PM
dj_seloe's Avatar
up
Old Aug 16, 2011 | 06:42 AM
dj_seloe's Avatar
honda-tech gets first dib on this.....
Old Aug 18, 2011 | 06:57 AM
dj_seloe's Avatar
no dj's on here wanna jump on this???
must go elsewhere then...
keep it up till it sells.
Old Aug 18, 2011 | 08:06 AM
ek97sedan's Avatar
vinyl
Old Aug 18, 2011 | 09:35 AM
reznunt's Avatar
Old Aug 18, 2011 | 09:56 AM
HondaGuy951's Avatar
