3 inch header outlet!!!!
Old Jun 1, 2011 | 05:48 PM
88 EF Hatch's Avatar
Default 3 inch header outlet!!!!
Just bought a 4-2-1 jg header for my b16. Here is the question I have. I have a bone stock b16 with intake and I plan on slapping this header on it but the jg header was modified and has a 3 inch outlet after the 2 pipes become one for about 3 feet. Can this damage my motor? Should I have them modify it to a 2.5 outlet? Can I modified the 3 inch outlet after the 3 feet back to a 2.5 outlet so that I don't undo the beautiful weld job they did? Feed back please asap.
Old Jun 1, 2011 | 06:02 PM
bluehbcivic's Avatar
10 Year Member
Default Re: 3 inch header outlet!!!!
Old Jun 1, 2011 | 06:12 PM
Cynical 1's Avatar
just run a 3 inch exhaust?
or sell it and get what you want?
definitely NOT going to damage your engine in ANY way...
Old Jun 1, 2011 | 06:25 PM
DDTECH's Avatar
Anything past the merge is restriction basically.. You'll be fine, you wont have "optimal" low end, but it will make more power.
Old Jun 1, 2011 | 06:26 PM
So ur saying that with the bigger outlet ill have more top end hp but less low end? And should I run a 3 inch exhause or smaller?
Old Jun 1, 2011 | 06:57 PM
DDTECH's Avatar
A bone stock b16 will see gains with a 3'' exhaust, how much? That number is uncertain...search alittle bit, if the b16 is going to be stock, i'd go with a 2.5'' exhaust system behind the collector. Your motor isn't creating enough velocity flow to take advantage of a bigger pipe diameter, thats why on the low rpms, the car might not have "that low end".. then again, when has a b16 had low end LOL.
You'll be fine.
nikanoras
May 10, 2010 04:47 PM
98SGH
Feb 9, 2009 12:47 PM
S repcivicsir
Apr 19, 2005 05:30 PM
Rust
Mar 9, 2003 08:08 PM
IgniteTeg
Sep 16, 2002 06:49 PM
