02 Accord 4cyl timing belt help
Car has almost 106k and needs the timing belt and water pump changed for the first time. I know I am going to need 2 belts, the water pump, valve cover gasket. Is there anything else that I need to replace and can anyone point me to some directions for this? I already have the Haynes manual, but additional help would be appreciated. Is it worth going with Honda belts or will Gates belts be fine since they make Honda's anyways? Also, should I go with Honda water pump or is there another brand that will do the job? Thanks.
Once again, so much help from Honbeer....ps, that would be seal not seals on the cam shaft.
To the OP...Gates make a fine product IMO. I would also check into the Crankshaft seal....not good with the '02's but on the older gen's there was a balance shat and oil pump o-ring.
.OP: please check the FAQ page first before posting. most of your info can be found here. also if you plan to keep the car for a few years and will be doing your own work, do yourself a favor and buy a Helms factory service manual.
they are nearly identical from '90-'02 the major difference being a few added sensors and the chassis it's bolted to..
How does the Helms differ than the Haynes manual? Already have the Haynes so just wondering if it is worth buying another one.
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
jttca
Jun 11, 2011 04:11 AM
whitema
Apr 1, 2004 04:18 PM
chaps7931
Mar 3, 2004 08:31 AM
