Spoon N1 & Turbo thoughts?
Old Jun 1, 2011 | 12:27 PM
Records's Avatar
Default Spoon N1 & Turbo thoughts?
Hey guys, this might be in the wrong section but i didnt know where else to put it. im basically just wondering how spoon n1 exhaust will work with an turbo setup? from the things i've read on google mostly, is that spoon n1 is too restricted for turboes. the spoon n1's sound is just almostly like the perfect sound for hondas (IMO), so is there anyway spoon n1 could actually work with an turbo setup?
What are the thoughts about it?
Old Jun 2, 2011 | 05:59 AM
MR.johnson's Avatar
Default Re: Spoon N1 & Turbo thoughts?
try the forced induction area for better answers.
what are your power goals?
Old Jun 2, 2011 | 09:06 AM
FlewByU352's Avatar
You will be bottle necked for sure assuming most run a 3" downpipe. I was going to try it at one point regardless of the power I made I was keeping it on. But the all motor bug bit me and I was hooked.
Old Jun 3, 2011 | 12:06 PM
Records's Avatar
Looking for around 250whp +/-
not really much, but if its possible i'll higher the boost, for example when i am going to drag race etc (not always)
Why will i be bottle necked btw? and what are the consequences of running turbo with too less of a flow? (spoon n1) 2.4" +/-
Old Jun 5, 2011 | 07:12 AM
Records's Avatar
Bump
Old Jun 8, 2011 | 11:36 AM
tegdc4's Avatar
You could run it with one of those for normal driving and cruising but when you get on it or for track use run an 3" E-cut for better performance.
Old Jun 8, 2011 | 11:41 AM
tegdc4's Avatar
Running a exhaust with too much restriction will cause a turbo to not be as efficient because a turbo spools off of exhaust flow.
Old Jun 9, 2011 | 02:27 AM
civickiller's Avatar
Run a 3" full exhaust
running a smaller exhaust will only hurt your optimal power
Old Jun 10, 2011 | 03:12 PM
Records's Avatar
It'll mostly be an daily drive btw, and streetraces inbetween if i dont like spoon n1 after i've tested it i'll just resell and go 3"
im just afraid it'll be too loud for me ;P
Records
Jun 5, 2011 12:23 PM
gwakie
Apr 29, 2007 10:59 PM
rafael_dias
28
Dec 1, 2004 06:14 PM
AllMotorITR
Apr 15, 2002 11:19 AM
