► WANTED TO BUY ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jun/July 2011
This thread is a privilege so please abide by the rules. Users with several infractions to the rules are subject to losing % points, privilege, and/or being removed from the site.
RULES:
1. NO TRIAL USERS!
Once you sign up for honda-tech, you will be a trial user until you have at least 10 posts, belong as a member for 7 days, and do not lose any % points.
2. Prelude, specific classifieds only
This means no posting up anything other than prelude related items only.
3. One POST per month
Only one post per member per month. Multiple posts for different items will be deleted and you will be subject to privilege losses. You can edit existing posts if you have more items. This can be done by finding your original post and clicking EDIT. Deleting old threads and making a new one in order to remain on a newer page is also against the guidelines.
5. NO PICTURES
Pictures can be linked, but not inserted. Pics with IMG tags will be edited and/or deleted. Subject to point loss and/or privilege loss if done. Also, do not post in larger font sizes.
6. NO REPLIES OR COMMENTS
No replies or comments about anything listed. This is a READ-ONLY thread. Use IM or e-mail to contact the user. You can obtain this information by clicking the user-name of the individual posting the part for sale. If you are a trial user and cannot PM individuals you must wait until you are no longer a trial user to PM them. Do not change font size or color.
RECOMMENDATIONS:
7. Make a post in the classifieds and link it (optional, but recommended as you can receive no replies here)
8. As items sell, edit and/or delete your posts so the thread stays current. Although automatic cleanup will can your posts in 3 weeks. Do not change font size or color.
9. Save the text of your post, or you will have to re-write it every time it gets deleted.
RULES:
1. NO TRIAL USERS!
5. NO PICTURES
RECOMMENDATIONS:
WTB:
5th gen Horn bracket that connects from the radiator support to the horn.
Washer bottle top.
Washer bottle top.
I'm looking for 3 4th gen motor mounts, I just need there so If you got all four I'll send you a pic of the one I don't need
Also non-vtec rear speaker cover, mine got deeply scratched I just want a nice, cheap one
Passenger side window, no lock or window switch just the long window trim.
Rear passenger side mudflap
Looking for a perfect working condition prelude 5th gen (OBDII) distributor and ignition coil
Also a relay for the sunroof open/close (same relays)
Looking for 90-91 prelude fog light
this one http://t0.gstatic.com/images?q=tbn:A...Jb7_Bi1wgw&t=1
PM ONLY
PM ONLY
A good header
ITBs
Koni Yellows
JDM yellow fogs
Rotors
NSX calipers
RF fender liner
Rear sway bar (aftermarket)
Hondata S200
p28/72 (obd1)
DRIVER's Seat Belt
ITBs
Koni Yellows
JDM yellow fogs
Rotors
NSX calipers
RF fender liner
Hondata S200
p28/72 (obd1)
DRIVER's Seat Belt
Wanted:
97-01 Prelude rear hub/bearing assemblies (must be in good condition)
h22 water pump (new)
h22 timing belt (new)
Looking for a drivers side foglight bezel for oem 4th gen fogs.
Also needed, more urgently, o-rings for the water pipe on H22, for both ends if possible. OEM Honda only, since they are backordered until Sept.
