B series block choice!
Old May 31, 2011 | 05:15 PM
ej1_Bseries's Avatar
Default B series block choice!
whats up honda-tech, im new to this so sorry if i making a mistake, anyways i was woundering if some one can give me some hints about some B series block. I just droped of a b18b block that i built with CTR pistons at the shop, the guy said my block is most likly not gona be to good because i quess i messed up the piston wall pretty good, long story short im confused on what can be the most reliable/best set up i can do with high compression pistons. my choices are go with a b18b block again! or get a b18c1 or a b20 block? any info i would appreciate
Old May 31, 2011 | 05:37 PM
civichxtreme2's Avatar
Default Re: B series block choice!
It really kinda depends on what your gonna do with it, running high comp it really isnt gonna make too much of a difference with the black itself. Its the internals that really are gonna make a difference, But that being said the b20 is great for all motor due to a bit more torque available due to its size.
Old May 31, 2011 | 05:40 PM
i have a fuilly built b16 head, i want to go b20 because of the torque but im being told the b20 block arnt to reliable
Old May 31, 2011 | 05:46 PM
PandaEj6's Avatar
what head do you have? A nice, easy, 'craigslist' build that would make a very fun & comfortable daily driver...is a b18c1 block, p30 pistons, b16 head w/ bigger cams & valvetrain. That would net 11.3:1 comp w/ oem head gasket and 11.6:1 w/ a 2 layer gasket. While building it if you addressed arp rod bolts, arp head studs, and rod bearings, you could beat on it all day and be making 200whp. Cheap and effective
Old May 31, 2011 | 05:47 PM
Depends on what you put inside em, if you want a reliable build you need rods and pistons anyway, spring for somethign after market, make sure you use good rod bolts (apr) and a good oil pump and you should be fine. Your not boosting it to the moon so you should be good for 200-220 whp with that set up very reliably
Old May 31, 2011 | 05:57 PM
i have arp head studs and i do plan on picking up some arp rod bolts. its not going to be a daily car but something i can drive in the streets on nice days specially up here in MA which theres not to many >. Question all b20 blocks are obd2 correct? and if they are that means i have to buy a obd2 harnest?
Old May 31, 2011 | 06:01 PM
PandaEj6's Avatar
they are... but hells no you dont
Most are obd2 but the obd1 harness and ecu should work just fine. The VTEC is the only thing that you may have to look in to.....It depends on what your putting it in on whether or not youll need to wire anything up
Old May 31, 2011 | 06:02 PM
Beat me to it LOL
Old May 31, 2011 | 06:10 PM
thats some good news, so im thinking im going to go with the b20, just need find 1 for a hood price found 1 on Hmotorsonline.com for 700 with shipping, idk if you guys know some good sites
Old May 31, 2011 | 06:17 PM
H2BJON's Avatar
Search around, I'm from ma and I see b20 blocks all the time go for good prices you just need to mske sure you run the vins
Old May 31, 2011 | 06:39 PM
h2bjon.. yaa that the problem i know some ppl that there boys have 1 but i know they dont get it the way they should
Old May 31, 2011 | 06:57 PM
Depending on where you live you might be able to find an Importer, I got mine from a company in Orlando Fl for $550, but I could pick it up. Its a JDM B20 but there no difference really. They are common
dutchman5
Texas -OK -LA (Sales)
Oct 29, 2010 08:31 PM
jdmme09
Feb 8, 2009 03:08 PM
BrOkEn_Dc2
Apr 9, 2006 03:50 PM
majek
Oct 14, 2004 02:49 PM
2dark2bslow
Sep 28, 2002 05:11 AM
