K&N drop in filter...Something can't be right and must be a simple fix.
Old May 31, 2011 | 02:38 PM
justincredible1's Avatar
Default K&N drop in filter...Something can't be right and must be a simple fix.
I just bought a simple filter for the ITR and now after putting the stock air box lid back on I notice that the intake itself has a lot of play inside box when I move around the intake arm. The reason for it is because the K&N filter arm deletes that OEM piece that connects the arm and the air box together with the round gasket which encloses the box. See how in the picture below it's an open hole into the air box. The filter covers it but once you move the arm it moves all over the place. My question is how do you fix it or is this normal or should I just dump this K&N? Sorry for the lame post but I can't find any problems like this. Thanks
Old May 31, 2011 | 09:49 PM
tempsohc's Avatar
Default Re: K&N drop in filter...Something can't be right and must be a simple fix.
did you put the rubber gasket around the filter?
odiumred
Jun 22, 2007 11:27 AM
teggy21
Mar 5, 2006 09:38 PM
rev limiter
13
May 1, 2005 11:53 PM
Ill
Sep 10, 2004 09:56 AM
Extreme
21
Sep 8, 2003 10:49 AM
