Type R internals
Old May 31, 2011 | 12:43 PM
siopau's Avatar
Post Type R internals
hey guys iiwas wonderin where i can get new type R internals...... or is it even possible to get type R internals? correct me if im wrong.
thanks
Old May 31, 2011 | 12:46 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Type R internals
Japan.
Old May 31, 2011 | 01:12 PM
EJ8_Man's Avatar
Get P72 Rods, P72 Crank, and have them micro polished and balanced at a machine shop. Order P73-00 JDM pistons
PR3 Bearings (have a machinist tell you what color bearings to order)
Your block now has ITR internals. Do you need the head too?
Note: I should mention the ITR and GSR cranks are not identical, however they are identical in the sense they have the same bearing size, same rod length, same stroke
Old May 31, 2011 | 01:17 PM
siopau's Avatar
ohh okay. but do you guys know a site wherei can order it?
and EJ8 what do you mean by balanced? yeah i kinda want the head but depends on how much it is cuz of the budget
Old May 31, 2011 | 01:40 PM
EJ8_Man's Avatar
A machine shop will weigh the crank and spin it on a machine to determine if it is counter balanced correctly. If not they will remove metal in key areas to balance it
It would be probably be cheaper to find someone selling a short block B18C then to buy the parts new online. You'll have to get the bearings from some place like Majestic Honda, or find someone selling the set you need online.
Old May 31, 2011 | 01:50 PM
siopau's Avatar
yeah aye. alright thanks
Old May 31, 2011 | 03:22 PM
Deetz's Avatar
Crazy Honda Guy
Type r rods are a P73 also, they are stronger, not that is matters for most applications. The crank for the type R is heavier, and fully counter balanced setting it apart making it 30% smoother after 7000rpm...so don't think it's the same as a P72 gsr
Old May 31, 2011 | 08:16 PM
EJ8_Man's Avatar
The caps are from a GSR and are stamped P72. The push rods are stamped R and are P73. Thank you for the correction. As for the crank do you think balancing a GSR crank will be sufficient in a ITR application? I guess the argument against is Honda didn't think so
RoBsReX88
Feb 5, 2013 08:18 PM
MeathooK
Jul 13, 2008 09:42 AM
kenny7
May 9, 2008 02:55 PM
CivicGS-R
Dec 25, 2002 06:42 PM
