re-grind cams
Old Sep 30, 2002 | 05:34 PM
g4b17's Avatar
New User
Default re-grind cams
I would like some feed back on vtec regind cams. If anyone has some good or bad advice for me. If I use them it will be in a all motor crvtec.Thanks.
Old Sep 30, 2002 | 06:54 PM
Jared's Avatar
Default Re: re-grind cams (g4b17)
If done right, regrinds are just as good as a new core. Just make sure you're getting them from a place that isn't grinding off the base circle to make more lift, make sure they're welding to the core and then grinding off that. if the base circle is changed on a vtec cam, vtec may not engage. schneider does great regrinds.
Old Sep 30, 2002 | 07:20 PM
Francois's Avatar
Default Re: re-grind cams (Jared)
Well,I must say more...
I've got a friend that does regrind.
He has good knowledge for the D16 and now,he made the jump to the B-serie vtec.
The cam are grinded on the base circle and somemore.I've seen the cam myself and planning to buy some soon.
When you hear horror story about regrind cam,most likely,they are from a company that did welded the lobe.
The cam receive from the factory,a heat treatment(OEM).When you weld the lobe,you screw the heat treatment.Most likely,the welded spot will wear faster...and things get melty...
For now,he has 2 serie of cam.The first one is likely ITR cam.The second choices is like some Jun.
Btw,Vtec engage.
Serie 2 needs spring and retainer.But since we saved some dough for the cams,spring and retainer it's not that much...
[Modified by Francois, 11:21 PM 9/30/2002]
Old Oct 1, 2002 | 05:32 AM
Mover's Avatar
Default Re: re-grind cams (Francois)
Crower used to do this. I don't know if they still do. If your springs are to strong, the weld will break from the lobe eventually. Crower had this problem.
Old Oct 1, 2002 | 06:59 AM
earl's Avatar
Francois, don't know where you learned about reground cams but you are right on with your post. When regrinding a vtec cam, you also regrind the non-vtec lobes to match base circles. Otherwise vtec will not engage. You never want to weld on a cam because of the heat treating. Stock heat treating goes about .080" deep. Every reground cam has to have a smaller base circle, no only to add lift but to change duration. The trick is to not grind thru the factory heat treating. It is about impossible to increase duration without changing the base circle as was previously posted.
Old Oct 1, 2002 | 02:33 PM
Francois's Avatar
Default Re: re-grind cams (earl)
@Earl....I learned it from a friend that does regrind
I was,before I meet him,against regrind cam.
But,since then,I learned a lot from him and still learning.I also,change my mind about regrind.The only exception that I may be against a regrind,if it is a welded lobe....
He also make precaution(secret receipe) to have a lobe that will keep oil on the lobe.
From now on,I want regrind cam for my B16.Well,is cam.
Old Aug 7, 2012 | 10:55 AM
teggyluva90's Avatar
Post Re: re-grind cams (earl)
Nice i wonder what secret receipe he makes to make it keep oil on the lopes the world may never know like a tootsie pop! . ANyway who my friend is selling me JG 301 cams which are non-vtec regrind ls camshafts for my ls im planning to boost will it help me reach my goal which is 350whp! and i want to know more about this andthat cams spec, thank you. AN like wow this thread is old i was 12 when this thread started how embarressing. I guess people still use regrind cams or custom cams to their spec like i read in hondatuning mags etc like sheepey, web cams etc.
Brown-tec
Nov 3, 2005 08:41 AM
H22CL
Mar 20, 2005 10:35 AM
IN VTEC
Oct 6, 2002 10:03 AM
Mr.FBR
Nov 26, 2001 05:05 AM
