A/C PAG Oil Compressor
Old May 31, 2011 | 07:27 AM
Muckman's Avatar
Moderator in Chief
Default A/C PAG Oil Compressor
I replaced the A/C Compressor and I need to add PAG oil. Do I add the oil via the lines/service ports or pour it directly into the compressor itself before pulling vaccuum on the system? High side or Low side? Ive read the procedure can vary on different compressors. The Honda service manual doesn't specify where to add oil, just how much.
Old May 31, 2011 | 07:32 AM
Linked's Avatar
Default Re: A/C PAG Oil Compressor
ac service cart machines have the ability to inject oil into the system via the service ports, so i assume that adding it directly to the compressor is not always necessary. but i cant answer your question as to wether you can just pour it down the service ports. i'm guessing no
Old May 31, 2011 | 07:46 AM
Muckman's Avatar
Moderator in Chief
You can buy bottles (not pressurized cans) of PAG oil which are intended to pour into components that you replace.
I read here that you are supposed to pour it into the high side port of the compressor.
http://www.acura-legend.com/vbulleti...em-not-140612/
Zebra
Honda Civic (2006 - 2015)
Feb 8, 2018 08:21 PM
Rick1t
May 6, 2013 06:03 PM
minvikes
Jul 11, 2011 12:06 PM
JohnnyEF
Jul 28, 2009 08:02 AM
