D16y8 distributor mount broke
Old May 30, 2011 | 04:56 PM
Jessnness428's Avatar
Icon6 D16y8 distributor mount broke
The mounting hole for my distributor broke! Is there any way I can fix this? Or can I replace it? It is attached to the end of the rocker arm assembly. Can I move the screw to another location? Any help would be appreciated.
Old May 30, 2011 | 04:59 PM
98civdx's Avatar
Master Detailer
Default Re: D16y8 distributor mount broke
The distributor mount broke? Or the rocker assembly hole where the distributor bolts to broke?
Old May 30, 2011 | 05:39 PM
The rocker assembly hole. Broke in half.
Old May 30, 2011 | 06:57 PM
98civdx's Avatar
Master Detailer
Find a new rocker arm. Or find out if you can have it welded, drilled and then tapped again.
You need the 3 bolts for the distributor.
Old Jun 27, 2024 | 02:57 PM
G-dawg17's Avatar
How screwed am I here? The piece will fit back in but I doubt even if jb welded that it could hold the torques top bolt.
skhell
Jan 16, 2018 11:37 AM
blacktibby07
11
Feb 5, 2011 03:12 PM
RA61825
Mar 12, 2006 02:26 PM
