Ac?? For thousandth time. Sorry
Old May 30, 2011 | 10:11 AM
WhoUtink's Avatar
Default Ac?? For thousandth time. Sorry
Posting from my phone, and I have crappy service. So searching kinda sucks.
I know it has been covered before, and I have seen it, but I can't remember what it was called.
1994 accord lx. Under the glove box. Coming from the blower motor. These wires hanging down connected by twist-on connectors, get really hot and are starting to melt. Something is missing. What is it called?
The ac functions pretty well, but I know someone cut something out and connected the wires together.here is a blurry pic I just took, while we are driving. http://i253.photobucket.com/albums/h...3011134855.jpg
Old May 30, 2011 | 10:15 AM
WhoUtink's Avatar
Default Re: Ac?? For thousandth time. Sorry
So everyone knows. I am not driving and taking pics and posting.
I am in the back seat,
Old May 30, 2011 | 10:30 AM
poorman212's Avatar
Not sure of the year here, but anyway that should be "past" the resistor that controls the speed.....so is the motor just getting old and tired (drawing too much).
Old May 30, 2011 | 10:50 AM
WhoUtink's Avatar
Resistor. Ghats the word.lol. So the resister is higher up where it can't be seen?
Should take the motor out and ohm test it and doin by hand to see if it moves freel?
Old May 30, 2011 | 10:58 AM
poorman212's Avatar
Again, not sure what year you have here., kind of looks like a 5th gen (94-97)......but the wires "seem" to be a splice into the motor, which is why I said "after" the resistor.
Yes, you can always test the motor.
Old May 30, 2011 | 11:15 AM
WhoUtink's Avatar
Yes sir 1994. Thank you very much.
I cut the wires just now and reconnected them and have been running the ac for about ten minutes now. And it seems they are not getting hot. Inside the old connectors was some green corrosion. And the writes seemed burned and melted. Could a bad connection generate enough heat there ro burn you? Cuz they were getting really hot before
Old May 30, 2011 | 11:36 AM
poorman212's Avatar
Yes. At some point, know you are on the road, you'll want to take care of the connetion you just made....butt splice or a two wire pigtail and tape or heat shrink.....happy motoring.
Old May 30, 2011 | 02:55 PM
chikin pickle's Avatar
Yes, bad connections can generate heat if they have enough resistance. There is supposed to be a connector there.
carp_5
Acura TSX
May 26, 2019 02:11 PM
stacyorndorff
Apr 26, 2017 10:18 AM
usdmftw
Jan 28, 2013 08:18 PM
