transmission shift
Old Sep 30, 2002 | 04:44 PM
Pepsi90919's Avatar
Default transmission shift
i have a 1991 civic dx with the 4 speed automatic.
i'm coming from owning a 92 pontiac bonneville. i notice in this car the shifts are more defined, you can definitely feel them more.
i can also really feel at a stoplight, the 3-2 downshift. is this normal?
Old Sep 30, 2002 | 05:06 PM
Katman's Avatar
Default Re: transmission shift (Pepsi90919)
if you're talking about a jerky/shifting feeling in your Honda, yes that's normal. Most 88-91 civic/crx's (and 92+ civics) feel like that due to the lighter weight designed engine +transmission parts in contrast to a heavier Pontiac Bonneville.
Old Sep 30, 2002 | 05:43 PM
Pepsi90919's Avatar
Default Re: transmission shift (Katman)
also i should point out that i changed the transmission fluid (drain plug, god bless the japanese) ... 3.5L or so came out, is that the complete capacity? am i right in assuming there's no filter (it hasn't been mentioned in the haynes)?
it shifts through all gears and lockup works ok...
so i shouldn't worry about the downshift either? i'm sure it's the 3-2 downshift because you can feel a subtle 2-1 downshift after that. it doesn't feel like anything's broken it just feels more abrupt than in other cars.
Paco Ritter
Dec 21, 2015 08:29 PM
eritain
Nov 8, 2013 06:03 AM
Robunkus
Mar 22, 2012 10:16 AM
damgon
Transmission & Drivetrain
Aug 20, 2009 10:48 AM
94solchick
15
Jul 12, 2004 11:26 AM
