92 civic transmission
I have a 92 eg hatch, and lateley in the morning, my car doesn't like to shift out of second. After I drive it a little over half a mile, it makes a loud noise (sounds like when you drive through a big puddle) and then it finally shifts. It will shift fine the whole rest of the day, I only have problems with it in the morning, and my transmission fluid is fine. Anyone have any ideas???
Thanks
Lisa
Thanks
Lisa
Re: 92 civic transmission (honda92egchick)
are u sure the fluid is ok?? also check the linkage to make sure its hooked up ok. could be a bearing on the inside starting to fail?? i dunno...ive never heard that kinda problem before.
H-T Order of Merit
Is your trans an automatic or manual?
Not sure if this is true or not but I always heard that flushing a transmission can sometimes do more harm than good. I always heard to just change the fluid rather than flushing it. Like I said, this is something that I heard not knowing if there is any truth in it or not.
Re: 92 civic transmission (TouringAccord)
u would think it would be an auto, since u can shift outta second whenever you want with a manual.
H-T Order of Merit
Re: 92 civic transmission (carlton585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlton585 »</TD></TR><TR><TD CLASS="quote">u would think it would be an auto, since u can shift outta second whenever you want with a manual.</TD></TR></TABLE>
you'd figure but since it wasn't stated I figured I would ask
It's an auto. I heard that auto transmissions in hondas are crap anyway. I wish it was a 5 speed. I almost got one, but it's too expensive to switch over to that...too much stuff to buy. Maybe I'll change the fluid this weekend and see what it does.
H-T Order of Merit
I mean if it still doesn't fix the problem then maybe look into getting it flushed. But I just figure try the simpler and cheaper fix first.
Re: 92 civic transmission (BauleyCivic)
I like the idea of changing the fluid first...maybe that will temporarily help until I can save the money to get it flushed.
I also have a question about this forum...how do you become an active member of this thing? I can't find where you subscribe to it.
H-T Order of Merit
yep, no problem.
If I remember correctly, it used to be like 9 days or something. You might be able to find some info on it if you did some searching but I'm not sure.
Well, now my reverse is going up. It's like it gets stuck, and when it finally goes into gear, it goes "clunk" really loud, and the whole car shakes, then it's fine. Maybe I should consider saving up for a new transmission.
H-T Order of Merit
you might want to do that. I would say take it into a good transmission shop and have them look at it unless you can take it out yourself and know what to look for. Maybe at the same time you could do a auto-manual swap, that would probably be ideal. Don't know what your plan are but that what I would try to do.
kali.crooks.eg6
11-13-2013 11:15 PM
eritain
11-08-2013 06:03 AM
QueizaG
08-26-2009 10:46 AM
krisfnbs
10
12-08-2008 09:24 AM
