lots of usefull k-series parts
k20a2 water pump/oil cooler/water passage/hoses complete kit except the thermostat 200$
k20a2 oil pump 120$
k20a2 starter 150$
k20a2 alternator 150$
k20a2 oem flywheel oem 100$
k20a2 oem flywheel and oem clutch kit with a good disc 150$
intake rsx type-s 50$
vtec solenoid k20a2 complet 80$
VTC oil control valve k20a2 60$
IACV idle air control valve k20a2 60$
map sensor / crank sensor / cam sensor / knock sensor 40$
IAT sensor 20$
throttle body k20a2 without TPS 120$ with new hybrid racing TPS 200$
brand new hybrid racing TPS still sealed in bag 80$
k20a2 coil pack / ignition coil 80$ set of 4
k20 timing cover / chain case 80$
k-series valve cover 60$ if you want the spark plug cover tell me i will inclued it i have a few models
hondata heatshield gasket K20A2, K20A, K20A3, K20Z1 (RSX 02-06, Civic SI) 30$
AEM TRU-POWER pulley kit for k20a2 with the strap a little used but still in very good condition 150$
k20 or k24 auto tensioner 60$
timing chain k20 and k24 new, the bag was opened but kept in oil 60$
oil pump chain k20 and k24 new, the bag was opened but kept in oil 30$
timing chain guide left and right 60$ / pair
oil pump chain guide and tensioner 30$ / pair
timing chain tensioner 40$
k20 timing mount 20$
k20 or k24 crank pulley 30$
k20 or k24 crank sprocket 30$
k20 or k24 crank pulse plate 10$
exhaust cam gear (normal) 30$
intake cam gear (VTC) k20(50degree) or k24(25 degree) 60$
rsx-R oem dual valve springs and retainers 50$ (perfect for upgrading those single valve springs setups....)
clutch slave cylinder 30$
oem rsx-s fuel injectors 310cc high impedance 50$
I have a lot of other small parts but too much to list them... I have listed the biggest things so if you want you can private msg me and i will check if i have them (only ENGINE/MECHANICAL parts ... no CAR parts)
pra prb prc rba rbb rbc pna pnb
k20a2 oil pump 120$
k20a2 starter 150$
IAT sensor 20$
Rob Dizzle
Feb 7, 2004 07:53 AM
