b16a leak, need opinions
Old May 29, 2011 | 10:44 AM
Jdm John's Avatar
Default b16a leak, need opinions
Hey everyone I have a b16a in my 94 civic and it has started to leak oil. I have looked it up and people have said that it could be a number of things like the cam seal, vtec solenoid gaskets or the valve cover gasket. I'm trying to narrow it down to what it could be and if you could give your opinion on what you think it looks like it would be. Here are some pictures and thanks for any input you give.
Old May 29, 2011 | 10:52 AM
vitamin_c95's Avatar
Default Re: b16a leak, need opinions
check the o ring on dizzy too
Old May 29, 2011 | 10:58 AM
I would clean it up and start looking with a clean plate for that leak
Old May 29, 2011 | 10:59 AM
Jdm John's Avatar
I think i'll try that. But I'm wondering if its my head gasket or not?
Old May 29, 2011 | 08:17 PM
ej1Pat's Avatar
Mine looks the same on my b16a, and I thank it's my cam seal. And that was after I had cleaned it once. But if it's not the cam seal for you, post it for me.
Old May 29, 2011 | 08:21 PM
Former User's Avatar
Wipe your finger where the bottom of the distributor meets the head. Is there oil on your finger?
Old May 30, 2011 | 05:09 AM
delslo94b16a's Avatar
mine did the same thing it was the vtec solenoid gasket , I found that out after changing the valve cover gasket and cam seal
Old May 30, 2011 | 05:11 AM
NVturbo's Avatar
O.G. triple O.G.
Three possible things:
1. Cam seal plug
2. Distributor
3. VTEC solenoid
My guess is #1.
Spray some engine degreaser and clean that engine up. It is a PITA to do so when the oil is all caked up down the line.
sshiny007
38
Mar 7, 2010 01:19 PM
JDM91EF2
Oct 27, 2006 11:53 AM
H2290
Jul 22, 2006 06:48 PM
hella_usdm
Jun 2, 2006 06:50 PM
whitemike736
Jan 29, 2006 12:48 PM
