11:1 compression
Old Sep 30, 2002 | 04:26 PM
Foulker's Avatar
Default 11:1 compression
Is an 11:1 compression rate a good rate to do with a direct port nos kit or will it take away from the bottom end.... and will i have to go down in the shot of nos?
Old Sep 30, 2002 | 04:28 PM
Gennady's Avatar
New User
Default Re: 11:1 compression (Foulker)
It depends.
Old Sep 30, 2002 | 04:29 PM
Foulker's Avatar
Default Re: 11:1 compression (Wont be beat)
depends on what...because i was told that the higher compression the more top end you will have so would it take away from the bottom end and if so what do i need to do to build the bottom end?
Old Sep 30, 2002 | 04:36 PM
Gennady's Avatar
New User
You were told wrong. Your getting two totally different things confused here. Top and low end of a power curve, and top and bottom end of an engine.
It depends on the engine, other mods, state of tune, fuel, ignition, etc.
Old Sep 30, 2002 | 04:50 PM
niedejb's Avatar
The higher the compression the harder to tune under forced induction.
The higher the compression the more horsepower you make with a "X" sized shot (X being constant).
Compression greater than 10.5:1 should probably be reserved for all motor applications and not FI (but it can be done).
Old Sep 30, 2002 | 05:36 PM
SOHCArchangel's Avatar
Default Re: 11:1 compression (niedejb)
well n20 loves high compression, but your timing will have to be really retarded (no pun intended) a fuel system thats up to the task, and just to be on the safe side run the n20/fuel mixture a tad richer
Old Sep 30, 2002 | 05:52 PM
Gennady's Avatar
New User
Default Re: 11:1 compression (SOHCArchangel)
And some 94+ octane cant hurt either.
Old Sep 30, 2002 | 06:09 PM
yeah that too, super high octane is yu0r fraing
Accord CVCC
Apr 7, 2006 12:34 PM
1990hondaHF
Apr 8, 2004 11:38 PM
toooslow
Jul 3, 2003 09:48 AM
Fatty_1775
Mar 7, 2003 02:31 PM
Veil_Side_
Feb 14, 2002 02:24 PM
