$5 Comp Cams Degree Wheel Mount
Old May 28, 2011 | 06:33 PM
MarkOlson's Avatar
OG Hot Rodder
Default $5 Comp Cams Degree Wheel Mount
My son and I have a Comp Cams degree wheel in the tool box, but we were unable to find a crank socket that is compatible with Honda B-series crankshafts. Every mounting solution we saw on-line required a trip to a machine shop, so we decided to figure out a cheap, off-the-shelf solution.
Here is how we did it: http://accutach.com/Documents/CompCa...WheelMount.pdf
Old May 29, 2011 | 06:45 AM
leteg98's Avatar
Default Re: $5 Comp Cams Degree Wheel Mount
nice write up that's handy
Old May 29, 2011 | 08:49 AM
greenchad's Avatar
nice i have the same degree wheel, i assume the setup is almost the same for a d-series engine
Old May 29, 2011 | 11:12 AM
MarkOlson's Avatar
OG Hot Rodder
Looks like the D-series crank bolt is 14X29 and the B-series crank bolt is 14X31, so it should work exactly the same.
DEMNTD1
Nov 15, 2005 08:14 AM
743power
Oct 11, 2004 08:48 PM
Bnjmn
Mar 30, 2004 07:42 AM
