CRX no start, no power, good batt
Old May 28, 2011 | 12:44 PM
sxysweed's Avatar
Default CRX no start, no power, good batt
91 CRX DX. 215k miles.
Battery tested good on battery tester. Reads 12.8volts.
Grounds are good. ALL fuses in/out of the car (except for interior lights fuse inside, been broke a while) are good.
Starter, Alternator, and Battery have all be replaced in the last year and were working great.
Car doesn't start. Turn the key, no power to to the cluster. None of the normal lights light up.
No CEL, no oil light, no brake, no door ajar.
Replaced Ignition Switch, old one was worn out. Still no power/no start.
Any ideas?
Old May 29, 2011 | 07:26 AM
lazy14's Avatar
Default Re: CRX no start, no power, good batt
main relay? have you checked your grounds?
Old May 29, 2011 | 07:51 AM
eREXion91's Avatar
Do you have a picture of your engine bay near the battery source? I can probably spot your problem. Just take a pic of that part of the engine bay.
Old May 29, 2011 | 02:15 PM
Aftermath_Hatch's Avatar
It is simple whatever it might be,check your batt. termals,grounds,and main fuse your just lookin over something.
Old May 29, 2011 | 02:56 PM
89jdmcrxDOHCzc's Avatar
And you said you replaced the ignition switch but was it a brand new one? Sounds like you may have another faulty switch
Old May 31, 2011 | 09:54 PM
91_rex_ls-vtec's Avatar
do you have power to you eld fuse box? the fuse box in the engine bay? if not you wont get power to anything else.
Old May 31, 2011 | 10:37 PM
benny_ng's Avatar
had this happen on our lemons car. it was a bad wire from the battery to the starter. we literally yanked on it and it worked again. NO IDEA why.
Old Feb 6, 2016 | 06:15 PM
crazyhorse2011's Avatar
10 Year Member
Loved
bump
Old Feb 6, 2016 | 07:14 PM
acmoc's Avatar
Is everytthing plugged in at the fusebox?
Look and make sure
Cody Wilson
Apr 7, 2016 04:38 PM
ek9sb
Jan 24, 2011 05:48 AM
extensioncordy
34
Jan 30, 2007 03:38 PM
strils
Jan 11, 2007 08:06 PM
TurboFryBox
Apr 2, 2003 01:42 AM
