CEL light on... Code 6 and 43
Old May 28, 2011 | 09:53 AM
T-Mo's Avatar
Default CEL light on... Code 6 and 43
I just recently finished a mini me swap (b7/z6 head) I have yet to find a p28 ecu and haven't wired the vtec up yet. As I was test driving it yesterday, the CEL came on. I checked and code 6 and 43.
Code 6 I understand is for ect sensor. But this code 43 (fuel supply) is more difficult. I have a new o2 sensor so that not it. Could it be the wires? Because long story short, I had difficulty with timing tensioner bolt hole being stripped. Took it to a shop that heli coiled it for me and set timing and all that.
I purchased some cheap wires (vtec ones) from work to see if the car works before spending anymore money but the shop insisted on putting NGK wires on it. So they took the old NON vtec NGK wires and put them on there. They said all wires work the same.... Is this true or do you all think that the wires maybe triggering this code?
Old May 28, 2011 | 09:55 AM
grumblemarc's Avatar
The Grumpiest
Default Re: CEL light on... Code 6 and 43
Not the wires. Fix the issues causing the CELs directly.
Old May 28, 2011 | 10:48 AM
T-Mo's Avatar
Well.......that's what I'm asking. I changed the o2 sensor already. What else should be checked
Old May 28, 2011 | 12:34 PM
The Grumpiest
Uh. ECT sensor for starters.
Old May 30, 2011 | 07:19 AM
T-Mo's Avatar
figured it out... o2 sensor was not tightened all the way (code 43) and (code 6) with the aftermarket header, o2 sensor being loosened, the tail end was hitting rad fan and causing the fan blade to not spin freely......
Didn't have to change anything.
CrX EnTHUSIAST
May 1, 2017 08:39 AM
whiteboy9191
25
Feb 18, 2013 03:02 PM
blue_hatch
Feb 16, 2011 01:49 PM
