Catch can..etc..
Old May 27, 2011 | 10:07 PM
dirty_south's Avatar
Default Catch can..etc..
The set up: fully built ls-vtec turbo
The problem: oil overflowing from catch can, as well as blowing oil pan gasket. this is the third time ive replaced the oil pan gasket in 6 months, ive tried gasket maker and oem gaskets, all fail. i would assume both of the problems have the same cause, excessive pressure, as of right now im running two lines from the back of the block into the catch can (Moroso) and a third line to the valve cover. first of all is this correct? or should i vent the valve cover have two lines from valve cover, one from block? also could the location of the catch can matter.. as in the effects of gravity.. let me know your thoughts and ideas
Old May 28, 2011 | 04:48 AM
siblues's Avatar
Default Re: Catch can..etc..
The moroso catch can is known for puking oil in cars as well as the endyn.I would recomend using 4 lines two drains to the back of the block and two from the valve cover to the catch can.The can you have needs to be mounted really high in the bay so the drain on the bottom of the can has a downward slope back into the motor
Old May 28, 2011 | 07:55 AM
so on the catch can, theres three fittings, top, mid and bottom, top and middle to valve cover, and on the bottom runn a splitter with two two lines to the block? sorry im just trying to get this right this time
Old May 28, 2011 | 02:24 PM
siblues's Avatar
you dont need to split that line it isnt going to flow anymore oil just run the one line to the back of the block.I am going to say your problem isnt the can though you have excessive blowby and that isnt good.
Old May 28, 2011 | 02:51 PM
finally got under her today, and i didnt blow my gasket again, just seemed to loosen up from vibration/ heat and cold idk, tightened em back up then moved my can as high as i could in the bay, alot less oil seeped out and no more leak, theres only 2500 miles on this build so i hope its not blow by, but i do think my head gasket is bad, idk. its always something...im gonna run it like this for a week or so then pull the head off, its not overheating, just leaking on top of block next to tranny, no solenoid or distributor so im guessing hg....maybe head studs loosened. torque specs for arps?
Old May 28, 2011 | 05:11 PM
siblues's Avatar
I dont know the exact specs but I believe its between 75-85 for the studs its on their site and depending what you use to lubricate them the specs change.
LoveBrisk
Honda CR-V & Element
Jun 30, 2014 06:31 AM
LightningTeg
Nov 15, 2011 05:12 PM
stupidasso15
24
Oct 5, 2011 12:49 PM
Civic_07
29
Jul 6, 2009 06:05 PM
