Hondata S300 Calibrations
Old May 27, 2011 | 07:34 PM
Alta SiR's Avatar
Default Hondata S300 Calibrations
I just got a P08 Ecu with S300 for when I supercharge my B16A Civic. I would like to try it out by downloading a base-map for my stock engine with I/E/H, MSD ignition, etc. The only Calibration for the B16A N/A is the P30 JDM B16A basemap. Does this mean it is for a P30 ECU with S300, or is it just a map of the P30 and it can be downloaded to any S300 ECU?
Ironically, The P30 is the stock ECU in my car.... I just want to mess with the Hondata a bit and check out the launch control, etc.
Any advice would be greatly appreciated.
Old May 27, 2011 | 07:54 PM
mtber's Avatar
Default Re: Hondata S300 Calibrations
You can run the stock p30 calibration on a p28, p72, p30, p06 with vtec added etc.
If you run the p30 calibration on an ecu which does not have a knock board such as the p28, you will need to disable the knock sensor under the paremeters/misc tab.
Old May 28, 2011 | 06:04 AM
Alta SiR's Avatar
Thanks.
I have already disabled the knock and O2 heater. I was thinking that I should switch the S300 over to the P30 that I have. Would that be a waste of time?
Old May 28, 2011 | 07:09 PM
mtber's Avatar
Originally Posted by Alta SiR
Thanks.
There would be really no point if it is working ok in the p08 ecu.
Old May 28, 2011 | 08:23 PM
Alta SiR's Avatar
I downloaded the basemap, took a test drive as far as the gas station. Was idling a little high(1100 rpm) but seemed to run ok. Shut the car off for fueling and when I got going again the car hesitated at around 3400 rpm, almost like the rev limiter was engaging. Could I lose the basemap just by shutting the car off?
Obviously, this is beyond my ability. I think I'm going to find a tuner.
Old May 28, 2011 | 09:05 PM
mtber's Avatar
No, you can't loose the basemap by shutting the car off.
Old May 31, 2011 | 11:04 AM
Spunkster's Avatar
A P08 uses the s300j
A P30 uses the s300
You cannot swap it from one to the other as it will not fit.
Old May 31, 2011 | 11:49 AM
mtber's Avatar
I assumed he had a jdm p30.
There is such a thing as a usdm p30 ecu which uses the s300j too :-)
Old Nov 30, 2011 | 11:39 AM
Coreyg1's Avatar
if the knock sensor isnt disabled would that cause the s300 to shut off and not start back up?
Old Nov 30, 2011 | 12:18 PM
mtber's Avatar
The only time you would experience a problem with the knock sensor not being disabled is if you don't have an ecu with a knock board or a knock sensor wired up to the ecu etc.
jm_acura100
Engine Management and Tuning
Mar 25, 2014 06:29 PM
94EJ1Coupe
12
Mar 16, 2008 10:10 AM
RTW DC2R
Apr 4, 2006 09:42 PM
dav3ddt
Jul 7, 2004 06:37 AM
Eg6_JDM
Apr 14, 2002 07:47 PM
