throttle body and TPS questions
Old May 27, 2011 | 10:52 AM
Xtream_V's Avatar
Default throttle body and TPS questions
hey guys...my tps sensor recently went out and i was wondering what the factory intake manifold bore size was for throttle bodys was? the reason i'm asking is cause i was thinking about upgrading to a 68mm.
THEN on the other hand..i really don't mind the factory performance and the gains of a bigger throttle body are going to be minimal with my current mods. so is it possible to just drill out the factory TPS and re-tap it to fit in a b series tps from blox or some other company?
i've tried doing some searches but all i keep coming up with is factory throttle body sizes for b16, and gsr and nothing about using an aftermarket tps with a factory throttle body.
Thanks in advance for any and all help
Old May 27, 2011 | 12:05 PM
TypeRMOBBiN209's Avatar
Default Re: throttle body and TPS questions
Take off the the throttle body. The tps sensor should have like rivets to hold it in. Take a dremel or something like it and cut a notch on threw the rivets and it should just unscrew with a flat head.
Old May 27, 2011 | 12:43 PM
Quick99Si's Avatar
The OEM TB is 62mm though I'm not sure that it's port matched to the IM. The 68mm TB isn't worth the money on a near stock engine IMO, and yes, you can replace the TPS as described above.
Don't forget to calibrate it before final tightening!
Old May 27, 2011 | 01:38 PM
97CWITR's Avatar
Anyone know the bolt size and thread pitch to replace that dumb riveted bolt?
Old May 27, 2011 | 02:59 PM
didn't your tps come with 2 allen bolts to replace the riveted ones? my blox one did
Old May 27, 2011 | 03:02 PM
97CWITR's Avatar
Just looking to adjust it and replace those dumb bolts, I didn't buy a new sensor.
Old May 27, 2011 | 06:15 PM
Xtream_V's Avatar
woot! haha thanks!
yeah i knew the 68mm would be almost pointless for what my setup is now but the way i kinda look at things is that when it breaks it's time to upgrade lol...but i live in the real world and it just doesn't make sense right now to do it right now financially.
this is also my first time dealing with any tps issues though...how exactly do you calibrate the tps???
Old May 28, 2011 | 01:50 PM
get a multimeter. put positive on the middle wire of tps and negative to ground. you should read .5 closed throttle and 4.5 open throttle. keep adjusting till you get it right and tighten
lol my explanations suck though
Old May 28, 2011 | 02:11 PM
bgdriver's Avatar
I think the bolts are m5x.8 but don't hold me to it.
Old May 28, 2011 | 02:37 PM
Xtream_V's Avatar
they're not too bad if someone tries to make sense of it lol
but when you say adjust you're talking about adjusting the idle screw right? or the tps itself?
***also ordered a new tps today...hopefully it'll be here sometime this coming week.***
Old May 28, 2011 | 08:55 PM
haha i guess! the tps itself
Old May 29, 2011 | 08:33 AM
Quick99Si's Avatar
DO NOT TOUCH THE IDLE ADJUSTMENT SCREW
Swivel the throttle position sensor itself until you get the correct readings. Tighten, check voltage again, then adjust once more because you're bound to mess it up at least once. Backprobing the wires is difficult to do without assistance from a needle or maybe even a datalogging tool. Search this forum for "tps adjust" and you're bound to get dozens of hits
Old May 30, 2011 | 06:41 AM
IN VTEC's Avatar
Its m5x.8 with I think a length of 16mm with lock washer and washer.
EJtypeR
Jun 17, 2015 08:01 PM
turboef90
Mar 23, 2009 10:07 AM
Andre
Oct 25, 2004 03:18 AM
