rpm goes up EG h22a turbo
Old May 27, 2011 | 07:29 AM
sshh's Avatar
Default rpm goes up EG h22a turbo
car idle OK but after aggressive run on the car when pushing on clutch or being on neutral rpm goes up to about 3k after touching the gas pedal it goes back to good idle. looking the gas cable and throttle body from out side and it is not stuck, looked on TPS values from AEM ecu when it happens and it says throttle is open about 3% after touching the gas pedal it goes back to 0.
What could it be?
Thanks!
Old May 27, 2011 | 08:26 AM
md23vtec's Avatar
Default Re: rpm goes up EG h22a turbo
What could it be?
Thanks!
Sounds like you have a sticky throttle body
Old May 27, 2011 | 08:44 AM
sshh's Avatar
you think clean should help?
Old Jun 4, 2011 | 12:27 PM
sshh's Avatar
Ok throttle body cleaned and still having the same issue.
I tried to play with the TB when i cleaned it and it is not sticky at all.
I saw the TPS closed with one screw but it strong closed with honda bond i think.
any more ideas?
Thanks
Old Jun 6, 2011 | 10:42 AM
sshh's Avatar
bump for anyone idea...
UniqueX707
Jan 14, 2012 07:17 AM
sshh
Jun 8, 2011 06:52 AM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
Jdmbsixteen
17
Feb 18, 2004 07:54 PM
