I need help fixing a code 41.
Old May 27, 2011 | 06:21 AM
alex14's Avatar
Default I need help fixing a code 41.
OBD1 D16z6, OEM P28 ecu.
Car has been running great for the past 3 months with no CEL issues.
I was going down the road after being on the interstate for about 15 minutes and my car gives me a CEL. I flip my switch and it throws about 5 different codes.
6, 10, 20, 22, 41.
Car is still driving normal, no power loss to speak of, and no skipping or anything weird. I pull over and pull the ecu fuse. I checked all ground and all are in tact, especially the thermostat housing ground.
Now it is only throwing a code 41. I replaced the o2 with a known working o2 from my friends car and it is still throwing the code. I checked my wiring and there are no issues with it.
What could it be?
Old May 27, 2011 | 09:42 AM
ThatRicerDaniel's Avatar
Default Re: I need help fixing a code 41.
Could be bad ecu. Grab yourself a 5 dollar 02 simulator, wire that bad boy in and see if the CEL clears.
Old May 27, 2011 | 08:25 PM
alex14's Avatar
Any link to a o2 simulator? havnt seen one before.
Old May 28, 2011 | 09:14 AM
ef_cowboy's Avatar
its a resistor or diode,i think
Old May 28, 2011 | 10:12 AM
RA61825's Avatar
my code 41 when i had it was in my distributor. the little icm inside the distributor. If u can just get another distributer
Old May 28, 2011 | 01:28 PM
ef_cowboy's Avatar
http://www.corpusracing.com/communit...-you-will-need
Old May 28, 2011 | 01:29 PM
ef_cowboy's Avatar
you should try googleing soome times -----41 is o2 sesor heater...all it does is warm the o2 sensor on cold start...just repace the o2 if u dnt see any broken wiring
Old May 30, 2011 | 10:30 PM
alex14's Avatar
Read.
"I replaced the o2 with a known working o2 from my friends car and it is still throwing the code. I checked my wiring and there are no issues with it."
Old May 31, 2011 | 09:32 AM
This place should have some..
http://www.casperselectronics.com/store2/
Old Jun 1, 2011 | 09:29 PM
LBREF8's Avatar
Did you change it and reset the ecu properly?
Old Jun 1, 2011 | 09:55 PM
alex14's Avatar
I pulled (-) terminal off of the battery for about 10 hours. I suppose thats proper.
Kid-jdm-teggy
May 12, 2013 03:13 PM
GEIJIN
Aug 7, 2009 07:56 PM
suckawillis
Dec 18, 2004 08:07 AM
1.8Tities
Sep 9, 2003 02:11 PM
HYBRIDHATCH92
Aug 15, 2002 03:51 PM
