Couple tuning questions
Old May 25, 2011 | 01:11 PM
guy_from_nerk's Avatar
Default Couple tuning questions
I posted this in the FI forum with no answers, so i'll try my luck here
I am in the process of street tuning my built GSR setup and have come across a couple issues.
1st: I am running a hood exit exhaust, my tuner feels that an extender pipe must be ran to give an accurate reading of AFRs while tuning. Another friend of mine who tunes said that by running the pipe while tuning, it will throw the tune off once the pipe is removed....
2nd: While tuning we noticed that my AFR's would not drop below 12.0 under boost, no matter how much fuel was added ect. Tuner thinks its a software issue, other friend thinks my injector deadtimes are off
Anyone else have any opinions?
Old May 25, 2011 | 06:47 PM
ddd4114's Avatar
Default Re: Couple tuning questions
How far upstream of the exhaust outlet is the oxygen sensor placed?
What is your duty cycle when you can't enrich beyond 12:1? Have you checked for exhaust leaks before the oxygen sensor?
Old May 25, 2011 | 08:41 PM
outlet is atleast 8in away from o2, maybe 10-12 in actually. No exhaust leaks, duty cycle is low.
Car has 6262, deatschwerk 1000cc injectors with twin walbros, so I know im not out of fuel
Old May 26, 2011 | 07:16 AM
HAMOTORSPORTS's Avatar
The o2 placement is fine for accurate readings..
What tuning system are you using?
Old May 26, 2011 | 07:44 AM
Tuning with s300, its all up to date as well.
Old May 27, 2011 | 05:26 AM
mtber's Avatar
Try another wideband sensor.
Injector dead times in the calibration wouldn't cause such an issue.
Old May 27, 2011 | 08:07 AM
Wideband works fine, it came out of my buddies turbo hatch with no issues and it reads fine while cruising around. I wasn't sure if the deadtimes were the issue or not either as we set them up as Deatschwerks told us to
Old May 28, 2011 | 11:55 AM
Well we noticed that my gauge is reading 11.1-11.3 in boost, while Hondata is showing 12.1, any ideas what would cause the difference? in Smanager wideband is set to 0v=10, 5v=20, 5v=20.
One more question or issue I should say. We have a 6lb spring in the gate (precision 46mm) there is 3 ports on the gate. The top 1 is supposed to be left open if boost controller isn't hooked up. So we left that open. Now the other 2 ports is what were having an issue with. If we leave one of the side ports opened the car will hit 9psi (thats where boost cut is set at), if we plug both ports it will only hit 3.3psi
toony
Engine Management and Tuning
Mar 29, 2016 05:55 AM
guy_from_nerk
May 25, 2011 05:02 PM
egb18c5
Dec 31, 2010 06:20 PM
Azn Kenny
Oct 11, 2005 05:14 PM
proton
Aug 26, 2002 04:32 AM
