Cars compatible with '91 Honda Accords
Old May 25, 2011 | 06:40 AM
edifyexistence's Avatar
Icon2 Cars compatible with '91 Honda Accords
Searching for a manual window regulator for the driver's side window of a two door. Aren't many Honda Accords at the junkyards I frequent. You guys know of any cars that I could keep an eye out for that are made similarly?
Old May 25, 2011 | 06:15 PM
Default Re: Cars compatible with '91 Honda Accords
I called a few junk yards today to inquire again about their stock of 90-93 Hondas and since it was slim pickins I figured I'd throw the question at them. Of course, they said it has to be the same make and model.
What seems to be maddening to me is just that I took a regulator off a Toyota, I believe, and it looked quite similar in size and mechanism. Unfortunately I hadn't a chance to compare the two before closing time so I left it.
Certain things must be, as I know many cars have "brother" and "sister" companies, such as Dodge and Chrysler. This is just to the best of my knowledge; I'm not certain.
Old May 26, 2011 | 06:12 AM
fcm's Avatar
fcm
Old Fart
Where in Illinois are you, there are 3 PicknPulls in Illinois, a trip to Wadsworth, Summit or Hammond may be worth it... http://www.picknpull.com/check_inven...d&Distance=100
Maybe St. Louis is closer... http://www.picknpull.com/check_inven...rd&Distance=20
PicknPull also has one of the best X referance "list" I know of, tell them the MM&Y of car you have and what you need and they will give you a printout of every MM&Y of car with that same part, even tell you what row in their yard the car(s) is/are in.
We even have a few Accords at our PicknPull... http://www.picknpull.com/check_inven...rd&Distance=20 and who knows how many other cars with the same part.
Is your 91 a 2 or 4 door?
I think the regulator for a manual and power window is the same... http://www.picknpull.com/check_inven...rd&Distance=20 they do not show a diff. part #. 94
Old Jun 3, 2011 | 11:16 PM
If only organized junk yards were more common. I do believe the trip would be worth it; I'm sick of being pointed in random directions only to discover they no longer have the car they sent me off to search for.
My 91 is a 2 door.
I've been meaning to get my hands on an automatic regulator to check for differences. They only one that comes to mind is the motor, which can be removed presumably simply.
BigMac28
Jan 9, 2019 07:07 AM
102NDCAR
Jun 4, 2017 07:51 AM
Jared.Mann
Feb 24, 2017 05:57 PM
NJ Crx Person
Oct 20, 2003 04:55 PM
