95 h23 not running right
Old May 23, 2011 | 09:38 PM
krazoeg6's Avatar
Default 95 h23 not running right
i sent my car in to a shop to have a new head put on it after the last one cracked from past owner, it was running like a champ when i got it.
so now it sputters and limited to 3500 rpms
heres a crappy vid but it gets the point across ,
http://youtu.be/R_rBkf2ZEMc
im not a motor guy so i am lost any ideas on what it could be
Old May 24, 2011 | 04:18 AM
1GPlusSH's Avatar
Default Re: 95 h23 not running right
take it back to the guy. there may be some things you can try, but HE needs to make it right.
Old May 24, 2011 | 10:24 AM
circle22's Avatar
Hey my car is running to rich i was told so many diffrent thing could be any body can give me a hand
Old May 24, 2011 | 10:26 AM
1GPlusSH's Avatar
it could be a lot of different things. start a new post, and give detailed info
Old May 24, 2011 | 10:30 AM
circle22's Avatar
They tell it could be the throttle body or the ecu any idea
Old May 24, 2011 | 10:34 AM
typemismatch's Avatar
Honda owns me
^^ you sir are thread jacking, start your own thread and give details.
circle22's Avatar
I have 95 wagon went from a single cam to a swap h22 vtec i had it tun n stay said it was the fuel rail n fuel pressure regulator change dat n it still running rich cant find the prob so im trying see if any body has n idea wat could be
Old May 24, 2011 | 10:42 AM
circle22's Avatar
Sorry sir im new to this jusy trying get some help been putting money in to my car n nobody seem to know the prob
Old May 24, 2011 | 10:55 AM
krazoeg6's Avatar
what could make the ecu go into "limp" mode like that?
Old May 24, 2011 | 11:04 AM
1GPlusSH's Avatar
any number of CELs could. if it was running right before you took it there, you should take it back. don't spend your money figuring it out after you've paid somebody to work on your car that messed it up.
Old May 24, 2011 | 12:52 PM
circle22's Avatar
Wat kind of ecu can i use wit my h22 dohc vtec can i use i was told can also use a p72 wit my vtec is this true
sohcdestruction
Jan 28, 2009 02:47 PM
preludefien
Mar 4, 2007 03:12 AM
Pullig
Sep 28, 2006 01:19 PM
mck26
Oct 9, 2005 12:47 PM
dreams190
May 29, 2005 08:57 AM
