1991 Integra 4dr COMPLETE part out - perfect for EF build* CHICAGO
PICTURES WILL BE ADDED SHORTLY. IF YOU NEED PICS OF ANY PARTS, PM ME AND I WILL GET THEM ASAP.
Got this car from a co-worker in Chicago that didnt want it anymore because it needed a clutch. I took it and originally was going to make it my weekend track car, but the body/frame rust was just too extensive. So ive decided to part it out completely.
Everything is best offer
Below is the basic description of any major components and they're condition:
$800 - B18 obd0 complete longblock with 150k mi matching 5spd trans
ran great when it was pulled, had an oil leak from a cracked VC gasket. I already had purchased the clutch/flywheel, timing belt, ps/ac belt, tensioner pulley, h2o pump, and since i had it all apart i ordered a new headgasket for a piece of mind. All of these new never installed parts are included.
-Complete swap including engine harness, manifolds/gaskets, axles, mounts, ecu, gauge cluster
-BRAND NEW NOT INSTALLED: OEM clutch/flywheel, timing belt w/pulley, h2o pump, headgasket, vc gasket, IM/EM gaskets.
$100 - Headlights L/R
$40 - radiator
$75 - 4x100 steelies (2 decent tires, 2 junk)
$40 - Skunk2 weighted shift ****
$40 - radiator
grannyEK
Mar 17, 2013 05:32 PM
