Picture Log: BilletPro
This will be a informal picture log of our upcoming, newly revamped BilletPro
We have quite a few to make. Picking up more material today....
One in the machine being finished up.
All done
That's alot of shavings!
Some upclose pictures to show the detailed machining.
All done
so jealous of your tooling and equipment! i gotta get my manifold to you for the updates!
our of curiosity how heavy is the probillet manifold? and how heavy are the blocks before machining? looks great
Before any machining each block is 30lbs, so both blocks would be 60lbs!
Just after machining out the inside, the weight is reduced to 15lbs.
If I recall right, the plenum when 100% done weighted approx 6lbs last time. That was quite a while back so my memory might not be accurate. I will weight it when it is 100% done though.
Your roughly looking at somewhere between 54lbs and 50 lbs of shavings just for 1 plenum.
Looks amazing, I watched the video on this.
Whats a 30lbs block of aluminum cost?
How much are 30lbs worth of shavings worth?
What do you do with all those shavings?
That billet intake that what I was looking for before I did my new build but u guys didn't have it ready yet . Intake looking sick keep up the good work man
maybe you should make some billet accesories...valve covers, vtec solenoid delete, cam gears, shift *****, functional tow hooks not the pretty ones that are made for looks... alot of people want to support those that support the racers but not everyone can afford a billet 3k dollar intake manifold....the thing looks sick btw....is it gonna be like the kinsler intake that you can add,substract to the size of the plenum with spacers??
