complete 2001 B16 from a wreck into a 94 hatch.
Old Sep 30, 2002 | 12:29 PM
JD_B18CDX's Avatar
Default complete 2001 B16 from a wreck into a 94 hatch.
I'm confused on what needs to be done.
Do I
1. Bolt it in the 94hatch and use a chipped OBDI Ecu.
2. Bolt it in the 94 hatch and use the 2001 b16 ecu but get conversion from OBD1 to OBD2
BTW, with 2 versions of OBDII, will this matter for this swap or will the conversion harness take care of this.
Thanks in advance.
Old Sep 30, 2002 | 02:16 PM
letsride's Avatar
Default Re: complete 2001 B16 from a wreck into a 94 hatch. (johnd)
What car did this come from? Only the 99/00 SI's had the B16. 2001...?
Old Sep 30, 2002 | 03:18 PM
JD_B18CDX's Avatar
Default Re: complete 2001 B16 from a wreck into a 94 hatch. (letsride)
I take it back... its from a 2000 Si. Sorry for the wrong info... I blame it on the keyboard.. hehe.
Old Sep 30, 2002 | 04:53 PM
letsride's Avatar
NP... in that case I would go with option 1.
Old Sep 30, 2002 | 04:58 PM
YumVTEC's Avatar
umm, definitely stay obd1. gay to convert to obd2 in an obd1 car, when you're gonna want to run a chipped ECU or hondata eventually probly, and those are obd1 only.
Old Sep 30, 2002 | 06:11 PM
JD_B18CDX's Avatar
Default Re: complete 2001 B16 from a wreck into a 94 hatch. (YumVTEC)
So will a the engine wiring harness of the B16 bolt up to the EG chasis wiring?? (please remember, the whole swap is OBDII). Initially the pins look different... but not sure yet as I have not actully compated each one.
Dont I have to do something with the distributor and injectors?
Or should I get OBDI wiring harness for the engine as well?
[Modified by johnd, 10:13 PM 9/30/2002]
Old Sep 30, 2002 | 07:07 PM
deez92's Avatar
for less headaches get an obd2 wire harness from a teg. that way you don't have to change or rewire the injectors, dist. and stuff
Ryan bud
Dec 12, 2012 01:09 PM
No VDUBS here in206
14
Dec 24, 2008 09:02 PM
agy2k2
Feb 13, 2007 01:35 PM
turbo_civic_ek
Oct 28, 2004 02:16 AM
theslugbug
Oct 29, 2003 12:15 AM
