Misc D-Series parts, etc...
Old May 22, 2011 | 07:00 PM
NeonPinHead's Avatar
Default Misc D-Series parts, etc...
all prices are open to offers and include paypal fees. help me get rid of this stuff!
After something is sold it will be removed from the post. I respond fastest to PM's.
Chipped P28 5spd ECU $150 Shipped OBO
D16Z6 stock header heat shield painted black with VHT high temp paint - $15 shipped
Set of D16Z6 Head bolts - $20 Shipped
Set of D16Z6 Pistons and Rods not sure of the condition of bearings or rings - $45 shipped
D15B7 Camshaft and gear w/ new seal - $45 shipped
D15B7 bare block w/ main girdle - $25 picked up
D15B7 complete head - $25 picked up
Stock D16Z6 Flywheel - $35 shipped
Default Re: Misc D-Series parts, etc...
95 Civic Ex (D16Z6) OEM fuel pump ran perfect when pulled, went with walbro for turbo setup - $25 shipped
D15B7 oil pump - $20
D15B7 water neck with thermostat housing - $15
D15B7 head bolts - $10
D15B7 PCV Black Box - $10
D15B7 Brackets (ac, ps, motor mount) $15 each
D15B7 Timing belt covers $5 each
FMU - $15 shipped
Z1 EGR valve - $20 shipped
D15B alt. - $20 shipped
Z6 P/S Pump - $20 shipped
A/C Pulleys x2 - $10 shippd
another set of head studs
P/S Bracket - $10 shipped
OEM front tow hooks - $8 shipped
B7 lower timing belt cover - $10 shipped
coolant reservoir bracket - $5 shipped
alt. Bracket - $5 shipped
alt. bolts x2 - $3 shipped
exedy clutch and pressure plate - $20 shipped
unknown brand aluminum flywheel - $25 shipped
EJ1 rear center seat belt black - $15 shipped
clutch alignment tools x2 - $3 shipped
VC bolts - $2 shipped
all 4 OEM exhaust bolts w/ springs - $5 shipped
fuel filter bolts x2 - $2 shipped
EJ1 rear trunk emblem - $5 shipped
Misc. plugs w/ pigtails -$5 each shipped
Misc. Injectors - $5 shipped each
fuel pressure regulator - $5 shipped
map sensors x3 - $20 shipped
oil pressure sensor - $5 shipped
rad. fan switch - $5 shipped
IACV's x2 - $5 shipped
main relay - $10 shipped
bare Z6 manifold - $40 shipped
reserved1
Old May 22, 2011 | 07:06 PM
1sikhatch's Avatar
How much the aluminum flywheel weigh?
Old May 23, 2011 | 10:25 PM
Mikes2000civicsi's Avatar
what iacv's are they for? manual or auto? and is that bare z6 manifold for manual or auto as well. pm me when you get time, thanks
Old Jul 15, 2011 | 09:08 AM
HommeDeBois's Avatar
bump, pm sent about clutch, pressure plate, timing belt covers, etc.
Old Aug 2, 2011 | 11:19 AM
bump, are you still here?
Old Aug 2, 2011 | 03:51 PM
suichgo's Avatar
pm'd
trackreadyonlin
Feb 6, 2014 05:11 PM
dirtdiggler666
Aug 28, 2011 12:50 PM
bmw626
Jun 12, 2006 06:15 AM
