FS: Brand new Rosko Racking Euro R intake manifold
Like the title says i have a brand new Rosko racing Euro R intake manifold for h22's. it has the following:
-Injector area CNC ported to allow for USDM fuel injector spray patterns
-Machined clearance on flange for installation with stock intake manifold gasket
-Air injection holes in flange tapped and plugged
-Small 90 degree fitting on front of plenum removed and plugged
-Brake booster fitting removed and plugged and relocated to the rear of the plenum
-IACV adapter plate for USDM Idle air control valve
-EGR valve blockoff plate
-EGR cover plate
-Throttle cable bracket
-Fuel Rail adapter kit for specified fuel rail
-the Euro-R manifold also requires the use of a screw in style IAT sensor which is on the manifold and included
Now this sells for $575 plus shipping from Rosko Racing heres the link to their website so you can see it for yourself. ***Rosko Racing***
its part number 100-002
i am asking $500 firm picked up. Im in no rush to sell and I am located in valley stream, NY (long island) which is 10 minute away from JFK airport and 5 minutes away from green acres mall on sunrise highway. My number is 516 342 0318 thanks.
-EGR cover plate
